Introducción
This guide will show how to replace the motherboard of your OnePlus 6T. Make sure to use the correct tools and to be careful after removing the back cover of the device.
Qué necesitas
Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
Herramienta utilizada en este paso:Plastic Cards$2.99
Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
Remove the back cover from the phone.
Remove the single 3mm Phillips #00 screw to the right of the top rear camera.
3 personas más completaron esta guía.
