Saltar al contenido principal
OnePlus 6 Rear Camera Replacement
Qué necesitas
  1. OnePlus 6 Rear Camera Replacement, Back Panel: paso 1, imagen 1 de 1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
  2. OnePlus 6 Rear Camera Replacement: paso 2, imagen 1 de 2 OnePlus 6 Rear Camera Replacement: paso 2, imagen 2 de 2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
  3. OnePlus 6 Rear Camera Replacement: paso 3, imagen 1 de 2 OnePlus 6 Rear Camera Replacement: paso 3, imagen 2 de 2
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
  4. OnePlus 6 Rear Camera Replacement, Battery: paso 4, imagen 1 de 2 OnePlus 6 Rear Camera Replacement, Battery: paso 4, imagen 2 de 2
    • Grip the green tab connected to the battery and pull the battery directly up and out.
  5. OnePlus 6 Rear Camera Replacement, Midframe: paso 5, imagen 1 de 2 OnePlus 6 Rear Camera Replacement, Midframe: paso 5, imagen 2 de 2
    • The midframe is made of plastic and located above the battery space.
    • Using the Phillips #00 screwdriver, remove the ten 3 mm screws from the midframe.
    • ATTENTION - Be aware that the screw at the bottom left is marked wrong in this picture. The actual 10th screw is actually underneath the round white sticker. Do not remove the screw marked at bottom left, but strip over the white sticker which has a screw underneath it. Otherwise you will damage your midframe board.
    • Lift the bottom of the mid frame directly up and remove it from the device.
  6. OnePlus 6 Rear Camera Replacement, Motherboard: paso 6, imagen 1 de 1
    • Remove the ten screws holding the motherboard using a Phillips #00 screwdriver.
  7. OnePlus 6 Rear Camera Replacement: paso 7, imagen 1 de 2 OnePlus 6 Rear Camera Replacement: paso 7, imagen 2 de 2
    • Disconnect the small metal tabs near the battery compartment that are holding the motherboard down.
    • Using a fingernail, carefully work under the edge and pry the motherboard up from the phone.
    • The cameras should lift up with the motherboard.
  8. OnePlus 6 Rear Camera Replacement, Rear Camera: paso 8, imagen 1 de 2 OnePlus 6 Rear Camera Replacement, Rear Camera: paso 8, imagen 2 de 2
    • Lift up on the small tabs connecting the cameras to the motherboard to disconnect them.
    • Push on the lens side of the cameras and remove them from the motherboard.
Conclusión
Hunter Brown
Miembro Desde 09/28/21
100 Reputación
1 Guía escrita
Equipo
Clemson, Team 4-3, Hunter Fall 2021 Miembro de Clemson, Team 4-3, Hunter Fall 2021
CLEM-HUNTER-F21S4G3
5 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 37
Todo El Tiempo: 947
