Saltar al contenido principal
OnePlus 6 Midframe Replacement
Qué necesitas
  1. OnePlus 6 Midframe Replacement, Back Panel: paso 1, imagen 1 de 1
    • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
    • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
    • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
    • Repeat until the back panel is fully released.
  2. OnePlus 6 Midframe Replacement: paso 2, imagen 1 de 2 OnePlus 6 Midframe Replacement: paso 2, imagen 2 de 2
    • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
  3. OnePlus 6 Midframe Replacement: paso 3, imagen 1 de 2 OnePlus 6 Midframe Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
    • Completely remove the back panel from the device.
  4. OnePlus 6 Midframe Replacement, Battery: paso 4, imagen 1 de 2 OnePlus 6 Midframe Replacement, Battery: paso 4, imagen 2 de 2
    • Grip the green tab connected to the battery and pull the battery directly up and out.
  5. OnePlus 6 Midframe Replacement, Fingerprint sensor: paso 5, imagen 1 de 2 OnePlus 6 Midframe Replacement, Fingerprint sensor: paso 5, imagen 2 de 2
    • The midframe is made of plastic and located above the battery space.
    • Using the Phillips #00 screwdriver, remove the ten 3 mm screws from the midframe.
    • ATTENTION - Be aware that the 10th screw is actually underneath the round white sticker marked with the green circle at the bottom left. Do not remove the screw next to it marked with the orange circle or you will damage your midframe board.
    • Lift the bottom of the mid frame directly up and remove it from the device.
Conclusión
Una persona más ha completado esta guía.
Equipo
Clemson, Team 4-3, Hunter Fall 2021 Miembro de Clemson, Team 4-3, Hunter Fall 2021
CLEM-HUNTER-F21S4G3
Miembros de 5
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 71
Todo El Tiempo: 2,154
