Saltar al contenido principal
One Education Infinity:One Camera Assembly Replacement
Qué necesitas
  1. One Education Infinity:One Camera Assembly Replacement, Battery: paso 1, imagen 1 de 2 One Education Infinity:One Camera Assembly Replacement, Battery: paso 1, imagen 2 de 2
    • Use a spudger to disconnect the black bundled cable connector from the motherboard.
  2. One Education Infinity:One Camera Assembly Replacement: paso 2, imagen 1 de 3 One Education Infinity:One Camera Assembly Replacement: paso 2, imagen 2 de 3 One Education Infinity:One Camera Assembly Replacement: paso 2, imagen 3 de 3
    • Use a spudger to lift the black tab on top of the ZIF connector.
    • Slide the ribbon cable out of the connector.
  3. One Education Infinity:One Camera Assembly Replacement: paso 3, imagen 1 de 3 One Education Infinity:One Camera Assembly Replacement: paso 3, imagen 2 de 3 One Education Infinity:One Camera Assembly Replacement: paso 3, imagen 3 de 3
    • Use a spudger to flip up the black retaining flap on the ZIF connector.
    • Pull the folded ribbon cable straight out of the connector.
    • This ribbon cable must be disconnected before removing the battery because it is attached to the battery with adhesive.
  4. One Education Infinity:One Camera Assembly Replacement: paso 4, imagen 1 de 1
    • Use a spudger to pry the battery away from the device.
    • Always use ESD safe tools when working with delicate electrical components.
  5. One Education Infinity:One Camera Assembly Replacement, Camera Assembly: paso 5, imagen 1 de 3 One Education Infinity:One Camera Assembly Replacement, Camera Assembly: paso 5, imagen 2 de 3 One Education Infinity:One Camera Assembly Replacement, Camera Assembly: paso 5, imagen 3 de 3
    • Use a spudger to flip up the black flap on the camera's ZIF connector.
    • Pull the ribbon cable straight out of the connector.
  6. One Education Infinity:One Camera Assembly Replacement: paso 6, imagen 1 de 2 One Education Infinity:One Camera Assembly Replacement: paso 6, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Use tweezers to remove the black cushion surrounding the camera lens.
  7. One Education Infinity:One Camera Assembly Replacement: paso 7, imagen 1 de 2 One Education Infinity:One Camera Assembly Replacement: paso 7, imagen 2 de 2
    • Use tweezers to lift the camera assembly away from the device.
    • Lift straight up to avoid tearing the delicate ribbon cable on the retaining wall.
Conclusión
Taylor Bratsch
Miembro Desde 09/06/16
5,750 Reputación
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 15
Todo El Tiempo: 197
