Saltar al contenido principal
Introducción
Check to see if the back plate can be placed back onto the camera. Make sure there are an even number of clips on the back plate. If one or more clips seems to be broken, the back plate needs to be replaced.
Partes
No se especificaron partes.
  1. To begin, remove both .6 cm screws from the clip* side of the camera. After you have removed the two screws, remove both the clip and the plate behind the clip so that the inside of the camera is exposed.
    • To begin, remove both .6 cm screws from the clip* side of the camera.
    • After you have removed the two screws, remove both the clip and the plate behind the clip so that the inside of the camera is exposed.
    • *If one of more of the clips appear to be broken the back plate might need to be replaced.
Conclusión
Una persona más ha completado esta guía.
Grant Lee
Miembro Desde 21/01/15
201 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 4-6, Brown Winter 2015 Miembro de USF Tampa, Team 4-6, Brown Winter 2015
USFT-BROWN-W15S4G6
4 Miembros
6 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 131
