Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Aviso: Estás editando una guía de prerrequisito. Cualquier cambio que realices afectará a todas las 3 guías que incluyen este paso.
Inglés
Español
Traduciendo paso 1
Paso 1
Remove both 6 mm screws from the clip side of the camera. After you have removed the two screws, remove both the clip and the plate behind the clip so that the inside of the camera is exposed.
Clip Side Repair
  • Remove both 6 mm screws from the clip side of the camera.
  • After you have removed the two screws, remove both the clip and the plate behind the clip so that the inside of the camera is exposed.
  • If one of more of the clips appear to be broken, the back plate might need to be replaced.
Insertar traducción aquí
