Saltar al contenido principal
Oculus Rift Control Box Motherboard Replacement
Qué necesitas
  1. Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: paso 1, imagen 1 de 3 Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: paso 1, imagen 2 de 3 Oculus Rift Control Box Motherboard Replacement, Control Box Bottom Cover: paso 1, imagen 3 de 3
    • Use a plastic opening tool to carefully pry off the four rubber feet from the control box.
    • You have now revealed the four 9 mm Phillips #1 screws underneath the rubber feet.
  2. Oculus Rift Control Box Motherboard Replacement: paso 2, imagen 1 de 3 Oculus Rift Control Box Motherboard Replacement: paso 2, imagen 2 de 3 Oculus Rift Control Box Motherboard Replacement: paso 2, imagen 3 de 3
    • Use a Phillips #1 Screwdriver to unscrew the four 9mm Phillips screws on the bottom of the control box.
    • You can now remove the bottom lid of the control box. It should come apart easily.
  3. Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: paso 3, imagen 1 de 3 Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: paso 3, imagen 2 de 3 Oculus Rift Control Box Motherboard Replacement, Control Box  Motherboard: paso 3, imagen 3 de 3
    • Use your finger(s) to start lifting the motherboard from the control box casing. While doing so, use your other hand to push the DVI connector into the control box casing.
    • When the DVI connector has cleared the casing, lift the motherboard.
    • Be careful! There should be two sets of wires still connected to the control box - do not tug on them. Simply flip the motherboard over to access these wires.
    • When reassembling the device, ensure that all of the wires are clear of the buttons.
  4. Oculus Rift Control Box Motherboard Replacement: paso 4, imagen 1 de 3 Oculus Rift Control Box Motherboard Replacement: paso 4, imagen 2 de 3 Oculus Rift Control Box Motherboard Replacement: paso 4, imagen 3 de 3
    • Use a plastic opening tool or your fingernails to disconnect the grey wire connectors. To make removal easier, pry the left and right edges to carefully remove the connector.
    • Do so for both of the wires attached to the motherboard.
    • Now fully separate the motherboard from the control box casing.
Conclusión
Audrey Chan
Miembro Desde 01/12/15
201 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 70-5, Forte Winter 2015 Miembro de Cal Poly, Team 70-5, Forte Winter 2015
CPSU-FORTE-W15S70G5
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 1,078
