Saltar al contenido principal
NuVision TM800A510L Screen Replacement
Qué necesitas
  1. NuVision TM800A510L Screen Replacement, Screen: paso 1, imagen 1 de 2 NuVision TM800A510L Screen Replacement, Screen: paso 1, imagen 2 de 2
    • Use a Heat Gun to heat the sides of the device and loosen the adhesive.
    • Heat the adhesive/device to just barely too hot to touch.
    • Pry up the the back of the device.
    • This process works best if you go one side at a time.
  2. NuVision TM800A510L Screen Replacement: paso 2, imagen 1 de 1
  3. NuVision TM800A510L Screen Replacement: paso 3, imagen 1 de 1
    • Peel this connector off the device.
    • This is basically just a sticker, but go slow so you don't tear the connector.
  4. NuVision TM800A510L Screen Replacement: paso 4, imagen 1 de 1
    • Slowly pull the speaker out of its bed.
    • The speaker piece is glued down.
  5. NuVision TM800A510L Screen Replacement: paso 5, imagen 1 de 2 NuVision TM800A510L Screen Replacement: paso 5, imagen 2 de 2
    • If you have not done so already, de-solder the boards from the device.
    • De-soldering the wires right now makes sure none of the wires are damaged or broken when we move the components.
  6. NuVision TM800A510L Screen Replacement: paso 6, imagen 1 de 1
    • The touch screen should lift right out of the device.
  7. NuVision TM800A510L Screen Replacement: paso 7, imagen 1 de 1
    • Use the Heat Gun to heat the adhesive between the screen and edge protector.
    • Pry the two pieces apart.
    • Be careful of the circuit ribbon for the touch screen when prying the two pieces apart. The ribbon threads through both pieces.
    • Remember: Heating the device to 'almost to hot to touch' makes the process easier to work with.
    • Tip: Try the heating & prying process on one side of the device at a time.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 16
Todo El Tiempo: 2,402
