Introducción
Your time will be split between removing the back from the device and de-soldering. The charging port itself is actually soldered onto the bottom of the motherboard. To access it, it is best to remove the motherboard from the device.
Qué necesitas
Use a Heat Gun to loosen the adhesive on the underside of the back cover.
Use some prying tools to lift the back cover off of the device.
Casi Terminas!
Conclusión
