Introducción
If your Nook Simple Touch with Glowlight has an issue relating to its battery, such as not charging or dying very quickly, it may need a new battery. If so, here is the guide to replacing your Nook’s battery.
Before using this guide make sure you check out our trouble shooting page to rule out other issues like the charging port.
Never work on a device that is plugged into a power outlet. Before starting this guide, ensure that the Nook is powered off and the power adapter is disconnected.
Qué necesitas
Detach the white cable connector from the motherboard.
Remove the battery from the device.
