Saltar al contenido principal
Nook BNRV300 Power Button Replacement
Qué necesitas
  1. Nook BNRV300 Power Button Replacement, Power Button: paso 1, imagen 1 de 3 Nook BNRV300 Power Button Replacement, Power Button: paso 1, imagen 2 de 3 Nook BNRV300 Power Button Replacement, Power Button: paso 1, imagen 3 de 3
    • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
    • Turn the Nook over to find the power button along the back upper edge.
    • Wedge the spudger between the top of the power button and the upper edge of the device.
    • Push the tool down to pry the button up and off.
  2. Nook BNRV300 Power Button Replacement: paso 2, imagen 1 de 1
    • Using your fingers, take off the power button.
Conclusión
2 comentarios
My power button is not responding. Presumably I have to let the power drain because it won't shut off. Do i replace the button or the sensor beneath it?
Lydia Rice - Contestar
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 26
Todo El Tiempo: 804
