Saltar al contenido principal
Nook BNRV300 Battery Replacement
Qué necesitas
  1. Nook BNRV300 Battery Replacement, Power Button: paso 1, imagen 1 de 3 Nook BNRV300 Battery Replacement, Power Button: paso 1, imagen 2 de 3 Nook BNRV300 Battery Replacement, Power Button: paso 1, imagen 3 de 3
    • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
    • Turn the Nook over to find the power button along the back upper edge.
    • Wedge the spudger between the top of the power button and the upper edge of the device.
    • Push the tool down to pry the button up and off.
  2. Nook BNRV300 Battery Replacement: paso 2, imagen 1 de 1
    • Using your fingers, take off the power button.
  3. Nook BNRV300 Battery Replacement, Back Cover: paso 3, imagen 1 de 3 Nook BNRV300 Battery Replacement, Back Cover: paso 3, imagen 2 de 3 Nook BNRV300 Battery Replacement, Back Cover: paso 3, imagen 3 de 3
    • Peel off the white sticker that is covering the screw head.
    • Remove the one 2mm-long screw using a size T5 Torx screwdriver.
  4. Nook BNRV300 Battery Replacement: paso 4, imagen 1 de 1
    • Wedge an opening tool between the back cover and the front plastic border at the top of the device (near the power button).
    • This will require some force.
    • Slide the opening tool along the edges of the device, prying up until you are able to use your fingers to remove the back cover.
    • The back cover snaps as it pops off. This is normal.
  5. Nook BNRV300 Battery Replacement: paso 5, imagen 1 de 3 Nook BNRV300 Battery Replacement: paso 5, imagen 2 de 3 Nook BNRV300 Battery Replacement: paso 5, imagen 3 de 3
    • Use a spudger or your fingers to gently pry the connector out of the white socket.
    • The back cover is now fully detached.
  6. Nook BNRV300 Battery Replacement: paso 6, imagen 1 de 2 Nook BNRV300 Battery Replacement: paso 6, imagen 2 de 2
    • Use tweezers to remove the brass-colored threaded fastener from the Nook plastic casing.
  7. Nook BNRV300 Battery Replacement, Battery: paso 7, imagen 1 de 3 Nook BNRV300 Battery Replacement, Battery: paso 7, imagen 2 de 3 Nook BNRV300 Battery Replacement, Battery: paso 7, imagen 3 de 3
    • The battery is located on the inside back cover of the Nook.
    • Do not use metal tools when prying up the battery. This may puncture the battery and cause harm to you and/or your device.
    • Insert a nylon spudger beneath the clear plastic adhesive holding the battery to the back cover.
    • Work around the battery, peeling up all of the adhesive.
  8. Nook BNRV300 Battery Replacement: paso 8, imagen 1 de 2 Nook BNRV300 Battery Replacement: paso 8, imagen 2 de 2
    • Hold on to one of the adhesive tabs and pull up.
    • This will fully remove the battery from its compartment.
Conclusión
2 personas más completaron esta guía.
Un comentario
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 77
Todo El Tiempo: 2,579
