Saltar al contenido principal
Nook BNRV300 Back Cover Replacement
Qué necesitas
  1. Nook BNRV300 Back Cover Replacement, Power Button: paso 1, imagen 1 de 3 Nook BNRV300 Back Cover Replacement, Power Button: paso 1, imagen 2 de 3 Nook BNRV300 Back Cover Replacement, Power Button: paso 1, imagen 3 de 3
    • Power off your Nook before working on your device. Hold the power button for about 5 seconds and select the “Power Off” option.
    • Turn the Nook over to find the power button along the back upper edge.
    • Wedge the spudger between the top of the power button and the upper edge of the device.
    • Push the tool down to pry the button up and off.
  2. Nook BNRV300 Back Cover Replacement: paso 2, imagen 1 de 1
    • Using your fingers, take off the power button.
  3. Nook BNRV300 Back Cover Replacement, Back Cover: paso 3, imagen 1 de 3 Nook BNRV300 Back Cover Replacement, Back Cover: paso 3, imagen 2 de 3 Nook BNRV300 Back Cover Replacement, Back Cover: paso 3, imagen 3 de 3
    • Peel off the white sticker that is covering the screw head.
    • Remove the one 2mm-long screw using a size T5 Torx screwdriver.
  4. Nook BNRV300 Back Cover Replacement: paso 4, imagen 1 de 1
    • Wedge an opening tool between the back cover and the front plastic border at the top of the device (near the power button).
    • This will require some force.
    • Slide the opening tool along the edges of the device, prying up until you are able to use your fingers to remove the back cover.
    • The back cover snaps as it pops off. This is normal.
  5. Nook BNRV300 Back Cover Replacement: paso 5, imagen 1 de 3 Nook BNRV300 Back Cover Replacement: paso 5, imagen 2 de 3 Nook BNRV300 Back Cover Replacement: paso 5, imagen 3 de 3
    • Use a spudger or your fingers to gently pry the connector out of the white socket.
    • The back cover is now fully detached.
  6. Nook BNRV300 Back Cover Replacement: paso 6, imagen 1 de 2 Nook BNRV300 Back Cover Replacement: paso 6, imagen 2 de 2
    • Use tweezers to remove the brass-colored threaded fastener from the Nook plastic casing.
Conclusión
2 personas más completaron esta guía.
Un comentario
Check the comments on each step. There are some adjustments to the process to properly and safely take this apart.
dl200010 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 32
Todo El Tiempo: 632
