Saltar al contenido principal
Nokia 6085h Front LCD Display
Qué necesitas
  1. Nokia 6085h Front LCD Display, Battery: paso 1, imagen 1 de 1
    • Flip over the phone so that the back is facing up.
    • Pressing your thumb against the back cover, slide the cover off of the phone.
  2. Nokia 6085h Front LCD Display: paso 2, imagen 1 de 1
    • Remove the phone's battery.
  3. Nokia 6085h Front LCD Display, Front LCD Display: paso 3, imagen 1 de 3 Nokia 6085h Front LCD Display, Front LCD Display: paso 3, imagen 2 de 3 Nokia 6085h Front LCD Display, Front LCD Display: paso 3, imagen 3 de 3
    • With the phone closed, run a plastic opening tool along the seam of the top half of the phone.
    • Make sure to disconnect each of the five clips before proceeding to the next step.
    • There are two clips on each side of the phone and one on the top.
  4. Nokia 6085h Front LCD Display: paso 4, imagen 1 de 2 Nokia 6085h Front LCD Display: paso 4, imagen 2 de 2
    • Remove the four 3.2 mm screws from the front panel using a T6 Torx screwdriver.
    • The fourth screw is located under a fold in the ribbon cable.
  5. Nokia 6085h Front LCD Display: paso 5, imagen 1 de 3 Nokia 6085h Front LCD Display: paso 5, imagen 2 de 3 Nokia 6085h Front LCD Display: paso 5, imagen 3 de 3
    • Starting in the lower right corner, slowly begin to lift the tape that is holding down the front LCD and cables.
    • Be careful around the two ribbon cables attached to the tape. These cables are fragile.
    • Lift the tape from the board.
  6. Nokia 6085h Front LCD Display: paso 6, imagen 1 de 1
    • Using a plastic opening tool, lift the ribbon cable connection below the front LCD.
  7. Nokia 6085h Front LCD Display: paso 7, imagen 1 de 3 Nokia 6085h Front LCD Display: paso 7, imagen 2 de 3 Nokia 6085h Front LCD Display: paso 7, imagen 3 de 3
    • Using a plastic opening tool, slowly pry the LCD display from the bottom, releasing it from the glue that is holding it to the board.
Conclusión
2 personas más completaron esta guía.
Brett Balcer
Miembro Desde 10/04/10
240 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 4-46, Amido Fall 2010 Miembro de Cal Poly, Team 4-46, Amido Fall 2010
CPSU-AMIDO-F10S4G46
4 Miembros
14 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 1,101
