Saltar al contenido principal
Nokia 5310b XpressMusic LCD Screen Replacement
Qué necesitas
  1. Nokia 5310b XpressMusic LCD Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the back cover down with your thumb.
    • *Note: the battery cover is not shown in this picture
  2. Nokia 5310b XpressMusic LCD Screen Replacement: paso 2, imagen 1 de 2 Nokia 5310b XpressMusic LCD Screen Replacement: paso 2, imagen 2 de 2
    • Gently lift the battery with a fingernail and remove it from its housing.
    • *Note: the battery may be replaced or repaired at this step
  3. Nokia 5310b XpressMusic LCD Screen Replacement, Keypad: paso 3, imagen 1 de 3 Nokia 5310b XpressMusic LCD Screen Replacement, Keypad: paso 3, imagen 2 de 3 Nokia 5310b XpressMusic LCD Screen Replacement, Keypad: paso 3, imagen 3 de 3
    • On some models, the front case is screwed down from the back. Follow steps 5 and 6 FIRST to remove the camera cover and two T6 screws, before removing the faceplate.
    • Use the Spudger to gently pry up the edges of the front face plate
    • At the center of the faceplate edge below the music keys there is a small latch on each side.
  4. Nokia 5310b XpressMusic LCD Screen Replacement: paso 4, imagen 1 de 2 Nokia 5310b XpressMusic LCD Screen Replacement: paso 4, imagen 2 de 2
    • Lift up the keypad from the bottom with either the spudger or your finger.
    • Note: at this time the keypad can be removed and replaced
  5. Nokia 5310b XpressMusic LCD Screen Replacement, Motherboard: paso 5, imagen 1 de 1
    • Gently unsnap the back camera cover from the phone.
    • Lift the cover from the phone after it is unsnapped.
  6. Nokia 5310b XpressMusic LCD Screen Replacement: paso 6, imagen 1 de 2 Nokia 5310b XpressMusic LCD Screen Replacement: paso 6, imagen 2 de 2
    • Use the T6 torx screwdriver head to remove the 2 screws on either side of the camera
    • Flip over the phone and again us the T6 torx head to remove the 4 screws located at each corner of the white keypad base
  7. Nokia 5310b XpressMusic LCD Screen Replacement: paso 7, imagen 1 de 1
    • Unclip the faceplate plug (ribbon) located in the lower left corner of the motherboard
  8. Nokia 5310b XpressMusic LCD Screen Replacement: paso 8, imagen 1 de 2 Nokia 5310b XpressMusic LCD Screen Replacement: paso 8, imagen 2 de 2
    • Use the Spudger to pry up the 2 metal clips located near the center of the motherboard on both the left and right
    • At this point the phone should come apart into 2 pieces, the motherboard/LCD screen and the faceplate
  9. Nokia 5310b XpressMusic LCD Screen Replacement, LCD Screen: paso 9, imagen 1 de 1
    • Unclip the ribbon plug located on the top of the LCD screen that connects it to the motherboard.
Conclusión
6 personas más completaron esta guía.
Max Kirby
Miembro Desde 05/01/11
518 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 15-14, Regan Spring 2011 Miembro de Cal Poly, Team 15-14, Regan Spring 2011
CPSU-REGAN-S11S15G14
3 Miembros
8 Guías creadas
Un comentario
Thank you much! As efficient & thorough as it gets!
REDACTED FREE PRESS - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 10
Todo El Tiempo: 9,201
