Introducción
This guide will show you the steps on installing the shoulder buttons. This will be helpful if the shoulder buttons are not working properly.
Only replace the faulty shoulder button(s).
Qué necesitas
Pull down on the battery cover release lever and pull back to remove the cover.
Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
Remove the four 9-mm Phillips head screws with the Phillips #1 screwdriver.
Lift off the black plastic covers that secure the shoulder buttons.
4 personas más completaron esta guía.
Un comentario
Where can I buy replacement shoulder buttons? Mine are starting to get sticky and don't spring back as well as they used to. I've been looking but I can't seem to find them anywhere.
