Saltar al contenido principal
Nintendo WaveBird Wireless Controller Joystick Replacement
Qué necesitas
  1. Nintendo WaveBird Wireless Controller Joystick Replacement, Batteries: paso 1, imagen 1 de 2 Nintendo WaveBird Wireless Controller Joystick Replacement, Batteries: paso 1, imagen 2 de 2
    • Pull down on the battery cover release lever and pull back to remove the cover.
  2. Nintendo WaveBird Wireless Controller Joystick Replacement: paso 2, imagen 1 de 1
    • Remove both batteries from the device.
  3. Nintendo WaveBird Wireless Controller Joystick Replacement, Front Panel: paso 3, imagen 1 de 2 Nintendo WaveBird Wireless Controller Joystick Replacement, Front Panel: paso 3, imagen 2 de 2
    • Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
    • During reassembly, firmly hold the panels of the controller together while replacing the screws so the panels do not separate.
  4. Nintendo WaveBird Wireless Controller Joystick Replacement: paso 4, imagen 1 de 2 Nintendo WaveBird Wireless Controller Joystick Replacement: paso 4, imagen 2 de 2
    • Carefully turn over the controller and place it on a flat surface.
    • Slowly separate the top panel from the bottom panel.
    • The buttons are loose and may fall off the motherboard.
    • Once separated, set aside the top panel.
    • During reassembly, make sure the front panel lines up with the buttons so they slide back into place.
  5. Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: paso 5, imagen 1 de 3 Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: paso 5, imagen 2 de 3 Nintendo WaveBird Wireless Controller Joystick Replacement, Buttons: paso 5, imagen 3 de 3
    • Use tweezers to remove the buttons.
    • It may be easier to remove the A button off of the pad by lifting it with your fingers.
    • During reassembly, make sure all buttons are in their respective sockets so they match up with the front panel.
  6. Nintendo WaveBird Wireless Controller Joystick Replacement, Joystick: paso 6, imagen 1 de 2 Nintendo WaveBird Wireless Controller Joystick Replacement, Joystick: paso 6, imagen 2 de 2
    • Grab the base of the grey joystick cover with one hand and firmly hold down the rest of the controller with the other hand.
    • Pull off the grey joystick cover.
    • During reassembly, make sure the slots inside the joystick cover line up with the motherboard so it can fit back together.
Conclusión
7 personas más completaron esta guía.
Garrett Leung
Miembro Desde 04/16/13
955 Reputación
8 Guías creadas
Equipo
Cal Poly, Team 10-40, Amido Spring 2013 Miembro de Cal Poly, Team 10-40, Amido Spring 2013
CPSU-AMIDO-S13S10G40
4 Miembros
37 Guías creadas
Un comentario
Question. My wavebird joystick wobbles a lot and gets stuck in directions I’m not inputting. Will replacing the top of the stick fix this? Or would I have to solder a new analog stick to the board?
Golgamang - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 53
Todo El Tiempo: 9,176
