Saltar al contenido principal
Nintendo NES Advantage Joystick Replacement
Qué necesitas
  1. Nintendo NES Advantage Joystick Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the four sticky pads from the bottom of the device.
    • If the pads are stuck, use a spudger to remove them.
  2. Nintendo NES Advantage Joystick Replacement: paso 2, imagen 1 de 2 Nintendo NES Advantage Joystick Replacement: paso 2, imagen 2 de 2
    • Remove the six 8 mm screws from the bottom of the device with a Phillips #0 screwdriver.
    • Use your hands to pull the back panel away from the controller.
  3. Nintendo NES Advantage Joystick Replacement, Joystick Panel: paso 3, imagen 1 de 1
    • Remove the four 12 mm screws from the small square panel on the right with a Phillips #0 screwdriver.
    • While removing the last (fourth) screw, apply downward pressure on the panel. This will make it easier to remove the last screw because of the joystick spring on the other side of this panel.
  4. Nintendo NES Advantage Joystick Replacement: paso 4, imagen 1 de 2 Nintendo NES Advantage Joystick Replacement: paso 4, imagen 2 de 2
    • Remove the small square panel.
    • This panel is connected with wires to the main circuit board. To replace the joystick panel, you will need to desolder the wires. To learn more about soldering, refer to our Cómo soldar y desoldar conexiones guide.
  5. Nintendo NES Advantage Joystick Replacement, Joystick: paso 5, imagen 1 de 2 Nintendo NES Advantage Joystick Replacement, Joystick: paso 5, imagen 2 de 2
    • Using your hands, unscrew the ball on top of the joystick.
  6. Nintendo NES Advantage Joystick Replacement: paso 6, imagen 1 de 1
    • Pull the joystick through the back of the NES Advantage Gamepad.
Conclusión
Kristen Gismondi
Miembro Desde 11/12/14
73,422 Reputación
183 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
141 Miembros
17,757 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 112
