Saltar al contenido principal
Nikon D90 Rear Display Buttons Replacement
Qué necesitas
  1. Nikon D90 Rear Display Buttons Replacement, Removing Casing Screws: paso 1, imagen 1 de 2 Nikon D90 Rear Display Buttons Replacement, Removing Casing Screws: paso 1, imagen 2 de 2
    • Locate the screws on both sides of the camera.
    • Remove the four 6.3 mm Phillips screws using a PH00 screwdriver.
    • Be careful not to strip the screws.
  2. Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: paso 2, imagen 1 de 3 Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: paso 2, imagen 2 de 3 Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: paso 2, imagen 3 de 3
    • Use a plastic opening tool to separate the rear case from the camera.
  3. Nikon D90 Rear Display Buttons Replacement, Disconnecting the Ribbon Cables: paso 3, imagen 1 de 2 Nikon D90 Rear Display Buttons Replacement, Disconnecting the Ribbon Cables: paso 3, imagen 2 de 2
    • After, remove the two orange ribbon connectors attached to the interior of the camera with tweezers.
    • Make sure to remove the ribbon cables carefully from the connectors to avoid damaging the camera.
  4. Nikon D90 Rear Display Buttons Replacement, Removing the Screws from the Rear Casing: paso 4, imagen 1 de 2 Nikon D90 Rear Display Buttons Replacement, Removing the Screws from the Rear Casing: paso 4, imagen 2 de 2
    • Remove the screws from the back assembly with a Phillips (PH00) head screwdriver.
    • Remove the ten 5.3 mm Phillips screws.
    • Remove the three 4.3 mm Phillips screws.
  5. Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: paso 5, imagen 1 de 3 Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: paso 5, imagen 2 de 3 Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: paso 5, imagen 3 de 3
    • Use a plastic opening tool to separate the LCD and metal plates from the casing.
  6. Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: paso 6, imagen 1 de 3 Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: paso 6, imagen 2 de 3 Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: paso 6, imagen 3 de 3
    • Use a plastic opening tool to separate the buttons from the casing.
    • Remove the 4.3 mm Phillips screw from the knob using a PH00 screwdriver.
Conclusión
Una persona más ha completado esta guía.
jonothon cawley
Miembro Desde 10/20/14
354 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team 1-7, Duarte Fall 2014 Miembro de UMass Dartmouth, Team 1-7, Duarte Fall 2014
UMASSD-DUARTE-F14S1G7
3 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 15
Todo El Tiempo: 2,572
