Saltar al contenido principal
Inglés
Español
Traduciendo paso 6
Paso 6
Use a plastic opening tool to separate the buttons from the casing. Remove the 4.3 mm Phillips screw from the knob using a PH00 screwdriver. Remove the 4.3 mm Phillips screw from the knob using a PH00 screwdriver.
Removing the Display Buttons
  • Use a plastic opening tool to separate the buttons from the casing.
  • Remove the 4.3 mm Phillips screw from the knob using a PH00 screwdriver.
Insertar traducción aquí
