Saltar al contenido principal
Nikon Coolpix S210 LCD screen Replacement
Qué necesitas
  1. Nikon Coolpix S210 LCD screen Replacement, Battery: paso 1, imagen 1 de 1
    • Place thumb on the battery cover panel on the bottom of the device.
    • Slide the panel to the right away from the camera.
  2. Nikon Coolpix S210 LCD screen Replacement: paso 2, imagen 1 de 2 Nikon Coolpix S210 LCD screen Replacement: paso 2, imagen 2 de 2
    • Slide the orange latch outward towards the corner of the camera.
    • The battery should pop out.
    • Remove the battery and reattach the cover.
  3. Nikon Coolpix S210 LCD screen Replacement, Back Case: paso 3, imagen 1 de 1
    • After removing the battery, unscrew the four 3.10mm screws on the side opposite the buttons.
  4. Nikon Coolpix S210 LCD screen Replacement: paso 4, imagen 1 de 1
    • Unscrew the three 4.05mm screws on the bottom of the camera below the lens.
  5. Nikon Coolpix S210 LCD screen Replacement: paso 5, imagen 1 de 1
    • Unscrew the two 4.05mm screws on the side next to the buttons.
  6. Nikon Coolpix S210 LCD screen Replacement: paso 6, imagen 1 de 2 Nikon Coolpix S210 LCD screen Replacement: paso 6, imagen 2 de 2
    • Gently wedge the flat end of the spudger between the back case and the wrist-strap mount.
    • The wrist-strap mount is the thin metal piece on the side of the camera. Your camera may have the wrist-strap attached, but you will not need to remove it to continue.
    • Carefully pry the back case away from the camera and then gently lift it off.
  7. Nikon Coolpix S210 LCD screen Replacement, LCD screen: paso 7, imagen 1 de 3 Nikon Coolpix S210 LCD screen Replacement, LCD screen: paso 7, imagen 2 de 3 Nikon Coolpix S210 LCD screen Replacement, LCD screen: paso 7, imagen 3 de 3
    • Having removed the back case, the LCD screen should be sitting loosely on the camera, attached only by a wide ribbon and a narrow ribbon.
    • The ribbons are connected to and held in place by small plastic latches.
    • To remove the wide ribbon, gently pry the spudger underneath the black plastic latch where the ribbon connects and lift up. The ribbon should slide out easily.
    • Repeat the same process with the smaller ribbon, this time looking for a light blue latch.
  8. Nikon Coolpix S210 LCD screen Replacement: paso 8, imagen 1 de 1
    • Gently remove the LCD screen.
Conclusión
2 personas más completaron esta guía.
Mallory Arend
Miembro Desde 01/17/11
474 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 5-17, Amido Winter 2011 Miembro de Cal Poly, Team 5-17, Amido Winter 2011
CPSU-AMIDO-W11S5G17
6 Miembros
12 Guías creadas
Un comentario
Funcionou conforme descrito! Funciona para a Nikon Coolpix S203
geral - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 13
Ultimos 30 días: 22
Todo El Tiempo: 4,166
