Saltar al contenido principal
Nikon Coolpix L810 Motherboard Replacement
Qué necesitas
  1. Nikon Coolpix L810 Motherboard Replacement, LCD: paso 1, imagen 1 de 2 Nikon Coolpix L810 Motherboard Replacement, LCD: paso 1, imagen 2 de 2
    Herramienta utilizada en este paso:
    • Remove two 5 mm Phillips #000 screws on the right hand side of the camera located near the power button.
    • Use of precision tweezers to help remove loosened screws is suggested.
  2. Nikon Coolpix L810 Motherboard Replacement: paso 2, imagen 1 de 2 Nikon Coolpix L810 Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove two 5 mm Phillips #000 screws near the audio/video inputs on the opposite side near the flash component.
  3. Nikon Coolpix L810 Motherboard Replacement: paso 3, imagen 1 de 2 Nikon Coolpix L810 Motherboard Replacement: paso 3, imagen 2 de 2
    • Remove three 5 mm Phillips #000 screws on the bottom end of the camera.
  4. Nikon Coolpix L810 Motherboard Replacement: paso 4, imagen 1 de 1
    • Carefully detach the back side of the camera by lifting both ends, with moderate force wobble until loosened enough to remove.
  5. Nikon Coolpix L810 Motherboard Replacement: paso 5, imagen 1 de 2 Nikon Coolpix L810 Motherboard Replacement: paso 5, imagen 2 de 2
    • With the LCD screen facing towards you, flip the screen to the right.
  6. Nikon Coolpix L810 Motherboard Replacement: paso 6, imagen 1 de 3 Nikon Coolpix L810 Motherboard Replacement: paso 6, imagen 2 de 3 Nikon Coolpix L810 Motherboard Replacement: paso 6, imagen 3 de 3
    • Remove three 5 mm Phillips #000 screws located on the bracket.
    • Hold the camera with the lens facing downward to prevent the bracket from falling off once all screws are removed.
  7. Nikon Coolpix L810 Motherboard Replacement: paso 7, imagen 1 de 2 Nikon Coolpix L810 Motherboard Replacement: paso 7, imagen 2 de 2
    • Disconnect the ribbons that connect the LCD screen to the camera gently using precision tweezers or fingers.
  8. Nikon Coolpix L810 Motherboard Replacement, Motherboard: paso 8, imagen 1 de 3 Nikon Coolpix L810 Motherboard Replacement, Motherboard: paso 8, imagen 2 de 3 Nikon Coolpix L810 Motherboard Replacement, Motherboard: paso 8, imagen 3 de 3
    • Remove three 5 mm Phillips #000 screws bordering the motherboard.
  9. Nikon Coolpix L810 Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove the plastic component located directly behind the flash from its rubberized holder.
  10. Nikon Coolpix L810 Motherboard Replacement: paso 10, imagen 1 de 1
    • Remove the electric tape covering the wires.
  11. Nikon Coolpix L810 Motherboard Replacement: paso 11, imagen 1 de 3 Nikon Coolpix L810 Motherboard Replacement: paso 11, imagen 2 de 3 Nikon Coolpix L810 Motherboard Replacement: paso 11, imagen 3 de 3
    • Unsolder all the wires that are on the top of the motherboard near the flash component.
  12. Nikon Coolpix L810 Motherboard Replacement: paso 12, imagen 1 de 1
    • Unsolder the wires on the bottom end of the motherboard.
Conclusión
2 personas más completaron esta guía.
Emilio Mena
Miembro Desde 01/14/15
776 Reputación
4 Guías creadas
Equipo
UW Tacoma, Team 3-1, Rose Winter 2015 Miembro de UW Tacoma, Team 3-1, Rose Winter 2015
UWT-ROSE-W15S3G1
4 Miembros
8 Guías creadas
4 comentarios
The guide is incomplete! Do not try to remove the mobo for it is soldered to some other tiny board under the on/off switch. Trying to remove the mobo after just unscrewing it, may guide to certain and permanent destruction of both PCBs!!!
symeonleriou - Contestar
any clue how to get tiny mobo out with mobo after taking screw out of tiny one at on/off switch?
jon baker - Contestar
This guide should be for beginners, Mr. Symeon Leriou, and you will not only write "Mobo", but also motherboard or Mainboard or Hauptplatine (deutsch)
But I agree with you that it is not complete.
The motherboard is soldered to the on / off board (power supply for the batteries).
Soldering again is almost impossible ...
lothar4460 - Contestar
Exactly! The guide is GOOD but it is incomplete!
The solder removal is insufficient to release de motherboard.
How to do it?
ramos.eng - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 18
Todo El Tiempo: 3,329
