Introducción
Use this guide to replace the motherboard on your Nexus 9.
Qué necesitas
With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
Use a spudger to disconnect the front-facing camera ZIF connector.
Use a pair of tweezers to gently lift the front-facing camera up from the motherboard.
Carefully peel up the copper shielding with your fingers.
Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
Using the spudger tool, carefully remove the bottom of the battery from it's location below the logic boards.
The battery is attached to the motherboard with some adhesive, so you may need an iOpener to loosen up the adhesive. Check out the iOpener guide for info on how to do it.
Do not pull the battery from the tablet yet, as it is still connected to the motherboard.
Remove the three 3 mm T5 Torx screws.
Remove the five 2 mm Phillips #000 screws.
Refer to the rear-facing camera replacement guide to remove the rear-facing camera from the motherboard and transfer it to the new one.
The motherboard remains.
5 personas más completaron esta guía.
2 comentarios
It is not necessary to remove the battery, just disconnect it. And you don't need to take all the copper off, just take it back to the battery.
Hi all will you please help me where i can find the replacement motherboard for nexus 9 ?
My email is rinold83@gmail.com
