Saltar al contenido principal
Nexus 5X Front-Facing Camera Replacement
Qué necesitas
  1. Nexus 5X Front-Facing Camera Replacement, SIM Card Tray: paso 1, imagen 1 de 3 Nexus 5X Front-Facing Camera Replacement, SIM Card Tray: paso 1, imagen 2 de 3 Nexus 5X Front-Facing Camera Replacement, SIM Card Tray: paso 1, imagen 3 de 3
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Nexus 5X Front-Facing Camera Replacement, Rear Panel: paso 2, imagen 1 de 3 Nexus 5X Front-Facing Camera Replacement, Rear Panel: paso 2, imagen 2 de 3 Nexus 5X Front-Facing Camera Replacement, Rear Panel: paso 2, imagen 3 de 3
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
  3. Nexus 5X Front-Facing Camera Replacement: paso 3, imagen 1 de 3 Nexus 5X Front-Facing Camera Replacement: paso 3, imagen 2 de 3 Nexus 5X Front-Facing Camera Replacement: paso 3, imagen 3 de 3
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
  4. Nexus 5X Front-Facing Camera Replacement: paso 4, imagen 1 de 2 Nexus 5X Front-Facing Camera Replacement: paso 4, imagen 2 de 2
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
  5. Nexus 5X Front-Facing Camera Replacement, Midframe: paso 5, imagen 1 de 1
    • Remove the ten 3.6 mm Phillips screws that secure the midframe.
  6. Nexus 5X Front-Facing Camera Replacement: paso 6, imagen 1 de 2 Nexus 5X Front-Facing Camera Replacement: paso 6, imagen 2 de 2
    • Insert an opening pick into the SIM card tray slot and twist the opening pick sideways to release the plastic clips.
  7. Nexus 5X Front-Facing Camera Replacement: paso 7, imagen 1 de 2 Nexus 5X Front-Facing Camera Replacement: paso 7, imagen 2 de 2
    • Continue sliding the opening pick around the upper part of the midframe to release the plastic clips.
  8. Nexus 5X Front-Facing Camera Replacement: paso 8, imagen 1 de 2 Nexus 5X Front-Facing Camera Replacement: paso 8, imagen 2 de 2
    • Use the plastic pick to pry open the plastic clips on the long edge of the midframe and on the bottom edge.
    • Make sure the clips on the long edge are released. The midframe is prone to break here if they are not disconnected properly.
  9. Nexus 5X Front-Facing Camera Replacement: paso 9, imagen 1 de 2 Nexus 5X Front-Facing Camera Replacement: paso 9, imagen 2 de 2
    • Make sure all the clips are free.
    • Carefully remove the midframe.
  10. Nexus 5X Front-Facing Camera Replacement, Battery Disconnect: paso 10, imagen 1 de 2 Nexus 5X Front-Facing Camera Replacement, Battery Disconnect: paso 10, imagen 2 de 2
    • Use the edge of a spudger to pry up and disconnect the battery flex cable located at the bottom right of the motherboard.
  11. Nexus 5X Front-Facing Camera Replacement, Front Facing Camera: paso 11, imagen 1 de 2 Nexus 5X Front-Facing Camera Replacement, Front Facing Camera: paso 11, imagen 2 de 2
    • Use the flat end of a spudger to pry up and disconnect the front-facing camera flex cable.
  12. Nexus 5X Front-Facing Camera Replacement: paso 12, imagen 1 de 1
    • Use a pair of tweezers to remove the front-facing camera from its recess.
Conclusión
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
3 personas más completaron esta guía.
Dominik Schnabelrauch
Miembro Desde 11/23/16
203,353 Reputación
682 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,817 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 2,224
