Saltar al contenido principal
Nexus 5 Antenna Cable Replacement
Qué necesitas
  1. Nexus 5 Antenna Cable Replacement, Remove the Battery Door: paso 1, imagen 1 de 1
    • The battery door of the Nexus 5 is held together with plastic clips.
    • Use the plastic spudger to separate the battery door.
  2. Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: paso 2, imagen 1 de 3 Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: paso 2, imagen 2 de 3 Nexus 5 Antenna Cable Replacement, Unscrew the Midframe and Speaker Assemby: paso 2, imagen 3 de 3
    • Using your #00 Philips Screwdriver, remove the six screws holding the midframe in place.
    • Remove the four screws at the bottom of the device holding the speaker assembly in place.
    • The screw on the far right may be covered in adhesive. Use your plastic spudger to remove the adhesive covering the screw.
  3. Nexus 5 Antenna Cable Replacement, Remove the Midframe and Speaker Assembly: paso 3, imagen 1 de 2 Nexus 5 Antenna Cable Replacement, Remove the Midframe and Speaker Assembly: paso 3, imagen 2 de 2
    • Remove the midframe and speaker assembly.
  4. Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: paso 4, imagen 1 de 3 Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: paso 4, imagen 2 de 3 Nexus 5 Antenna Cable Replacement, Remove and Replace the Antenna Cables: paso 4, imagen 3 de 3
    • The antenna cables are located on the right and left side of the battery (one is gray, the other is black).
    • Using your plastic spudger, disconnect both ends of the antenna cables.
    • Connect your new antenna cables.
    • Make sure the antenna cables are securely connected.
  5. Nexus 5 Antenna Cable Replacement, Reassemble the Device: paso 5, imagen 1 de 2 Nexus 5 Antenna Cable Replacement, Reassemble the Device: paso 5, imagen 2 de 2
    • Screw the midframe and speaker assembly back into place.
    • Push the outer edges of the battery door down until you hear the plastic clips "click."
    • Hold the power button until you feel the phone vibrate and/or see the Google logo displayed.
Linea de Meta
Una persona más ha completado esta guía.
Tyler Caldwell
Miembro Desde 12/07/17
181 Reputación
1 Guía escrita
Equipo
IUPUI, Team S1-G1, Baechle Fall 2017 Miembro de IUPUI, Team S1-G1, Baechle Fall 2017
IUPUI-BAECHLE-F17S1G1
2 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 2,783
