Saltar al contenido principal
Newport HT70 Pump Assembly Replacement
Equipo médico
El fabricante de este equipo médico no ha avalado o contratado a iFixit ni a esta guía de reparación.
Qué necesitas
  1. Newport HT70 Pump Assembly Replacement, Pump Assembly: paso 1, imagen 1 de 1
    • Position the base assembly so that you may access it.
    • Using the #1 Phillips screwdriver, unscrew the four screws (SCR3219P in the photo) and the two screws (SCR3232P) securing the base plate.
  2. Newport HT70 Pump Assembly Replacement: paso 2, imagen 1 de 1
    • The base plate will then come apart from the rest of the device with the pump assembly attached to it, as depicted in the following photo.
    • Inspect pump assembly for any damage or looseness.
  3. Newport HT70 Pump Assembly Replacement: paso 3, imagen 1 de 1
    • If damage is found, replace the pump assembly by removing each tube individually and replacing as needed.
    • You may not need to replace the entire assembly if parts of it are still intact.
Conclusión
Merek McGill
Miembro Desde 04/07/20
520 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S7-G5, Paton Spring 2020 Miembro de Cal Poly, Team S7-G5, Paton Spring 2020
CPSU-PATON-S20S7G5
Miembros de 3
6 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 260
