Saltar al contenido principal
New Nintendo 2DS XL Front Buttons Replacement
Qué necesitas
  1. New Nintendo 2DS XL Front Buttons Replacement, Back Cover Removal Preparation: paso 1, imagen 1 de 1
    • Before starting the disassembly, remove
    • The stylus
    • Any game cartridge
    • The SD card
  2. New Nintendo 2DS XL Front Buttons Replacement, Back Cover Removal: paso 2, imagen 1 de 1
    • Unscrew the four 6mm tri-point screws located at the four corners of the bottom panel.
  3. New Nintendo 2DS XL Front Buttons Replacement, Case Separation: paso 3, imagen 1 de 2 New Nintendo 2DS XL Front Buttons Replacement, Case Separation: paso 3, imagen 2 de 2
    • Be careful when separating the bottom panel from the front casing to avoid breaking the three cables connected to the motherboard (two on each side and one in the rear).
    • Using a spudger, separate the back panel from the front casing by gently prying around the panel.
    • There are many clips along the hinge of the case, so it is recommended to work your way along one short side and the two long sides before finishing the last short side.
  4. New Nintendo 2DS XL Front Buttons Replacement: paso 4, imagen 1 de 3 New Nintendo 2DS XL Front Buttons Replacement: paso 4, imagen 2 de 3 New Nintendo 2DS XL Front Buttons Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Using tweezers, disconnect the two cables that connect the rear buttons on either side to the motherboard by gently pulling them upwards.
  5. New Nintendo 2DS XL Front Buttons Replacement, Battery Removal: paso 5, imagen 1 de 2 New Nintendo 2DS XL Front Buttons Replacement, Battery Removal: paso 5, imagen 2 de 2
    • Using a spudger, lift out the battery.
    • Be aware that there is a sticky pad holding the battery into its tray. It may be necessary to use multiple tools to gently pry the battery away from the tray and motherboard.
  6. New Nintendo 2DS XL Front Buttons Replacement, Motherboard: paso 6, imagen 1 de 2 New Nintendo 2DS XL Front Buttons Replacement, Motherboard: paso 6, imagen 2 de 2
    Comprar
    • There are 8 ribbon cables that need to be removed as shown in the picture.
    • 2 of connectors (in green) are friction fit, unlike the rest of the connectors. Remove the cable by pulling it out gently. Do not attempt to open or unlatch these connectors in any way. Doing so will break them.
    • For the remaining 6 (in red), use a pair of tweezers to flip the latches up and pull the ribbon cable out.
    • Note that the second picture shows a broken ribbon connector next to the joystick ribbon connector (to the right of the red arrow). Do not attempt to unlatch this connector as shown in the picture!
  7. New Nintendo 2DS XL Front Buttons Replacement: paso 7, imagen 1 de 2 New Nintendo 2DS XL Front Buttons Replacement: paso 7, imagen 2 de 2
    • Unplug the following wires from the motherboard using a pair of tweezers.
  8. New Nintendo 2DS XL Front Buttons Replacement: paso 8, imagen 1 de 2 New Nintendo 2DS XL Front Buttons Replacement: paso 8, imagen 2 de 2
    • Remove the seven 4.4 mm screws using a J00 (or iFixit's Phillips #00) screwdriver bit.
    • Remove the motherboard from the device.
  9. New Nintendo 2DS XL Front Buttons Replacement, Button Removal: paso 9, imagen 1 de 3 New Nintendo 2DS XL Front Buttons Replacement, Button Removal: paso 9, imagen 2 de 3 New Nintendo 2DS XL Front Buttons Replacement, Button Removal: paso 9, imagen 3 de 3
    Comprar
    • Lift off the rubber cover on the A, B, X, and Y buttons.
    • Using tweezers, lift out the buttons.
  10. New Nintendo 2DS XL Front Buttons Replacement: paso 10, imagen 1 de 3 New Nintendo 2DS XL Front Buttons Replacement: paso 10, imagen 2 de 3 New Nintendo 2DS XL Front Buttons Replacement: paso 10, imagen 3 de 3
    • Lift off the grey rubber cover on the start and select buttons.
  11. New Nintendo 2DS XL Front Buttons Replacement: paso 11, imagen 1 de 3 New Nintendo 2DS XL Front Buttons Replacement: paso 11, imagen 2 de 3 New Nintendo 2DS XL Front Buttons Replacement: paso 11, imagen 3 de 3
    • Lift off the grey rubber membrane on the D-pad.
    • Using tweezers, lift the D-pad out.
  12. New Nintendo 2DS XL Front Buttons Replacement: paso 12, imagen 1 de 3 New Nintendo 2DS XL Front Buttons Replacement: paso 12, imagen 2 de 3 New Nintendo 2DS XL Front Buttons Replacement: paso 12, imagen 3 de 3
    • Lift off the grey rubber membrane covering the home button.
    • Using tweezers, lift out the button.
Conclusión
5 personas más completaron esta guía.
Tim Newman
Miembro Desde 09/25/17
1,633 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S18-G6, Forte Fall 2017 Miembro de Cal Poly, Team S18-G6, Forte Fall 2017
CPSU-FORTE-F17S18G6
5 Miembros
20 Guías creadas
4 comentarios
after assembly, pressing ZL causes some kind of an electric short, and the console turns off immediately, help !
mos_boum - Contestar
This usually occurs when you break the lower screen's power ribbon cable connector. It is not a ZIF connector and "unlatching" it will break it causing a loose fit. The shoulder button presses against the ribbon cable causing it to shift in the connector resulting in the speakers popping and the device turning off.
Mike -
OK. Lets say I can now change the buttons for replacement purposes only. My question is :where on the earth i can find buttons to replace??????
Robert - Contestar
Now there is a full set of keys for 2dsxl. If you can't find it, you can google kasynparts
kasynlife - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 47
Ultimos 30 días: 267
Todo El Tiempo: 12,395
