Saltar al contenido principal
Network card Replacement
Qué necesitas
  1. Network card Replacement, Remove battery: paso 1, imagen 1 de 1
    • Be sure to remove the battery to prevent any electrical shortage.
  2. Network card Replacement, Remove the backpanel: paso 2, imagen 1 de 2 Network card Replacement, Remove the backpanel: paso 2, imagen 2 de 2
    • Loosen all four screws and remove the back panel.
    • Remove the back panel with a spudger. Start out as in the second photo to prevent the plastic from breaking. Work you're way around the panel to remove it.
  3. Network card Replacement, Remove the antenna wires: paso 3, imagen 1 de 2 Network card Replacement, Remove the antenna wires: paso 3, imagen 2 de 2
    • In the red circle is the network card
    • Remove the two wires (inside the green circle)
    • the wires are very fragile and need to be removed with care
  4. Network card Replacement, Remove the network card: paso 4, imagen 1 de 1
    • Place the spudger as shown in the photo. The network card will pop up. After that you can remove it and replace it with another one
    • The wires are very fragile, be aware!
Conclusión
To reassemble your device, follow these instructions in reverse order. Be sure to connect the wires the same as in step 3.
2 personas más completaron esta guía.
Robin Koch
Miembro Desde 03/25/17
289 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 784
