Saltar al contenido principal
Netgear Arlo Plastic Housing Replacement
Qué necesitas
  1. Netgear Arlo Plastic Housing Replacement, Battery: paso 1, imagen 1 de 3 Netgear Arlo Plastic Housing Replacement, Battery: paso 1, imagen 2 de 3 Netgear Arlo Plastic Housing Replacement, Battery: paso 1, imagen 3 de 3
    • Locate unlock switch on underside of camera and unlock it by sliding it.
    • Once unlocked, slide the cover out and up to open the battery housing.
  2. Netgear Arlo Plastic Housing Replacement: paso 2, imagen 1 de 1
    • Remove all 4 of the 3.0 Volt batteries from the battery housing.
  3. Netgear Arlo Plastic Housing Replacement: paso 3, imagen 1 de 1
    • Inspect prongs at the bottom of the battery housing to ensure that they are not bent or broken before replacing the batteries.
  4. Netgear Arlo Plastic Housing Replacement, Plastic Housing: paso 4, imagen 1 de 1
    • Remove the 2 (3.5mm) housing screws with a J0 screwdriver.
  5. Netgear Arlo Plastic Housing Replacement: paso 5, imagen 1 de 2 Netgear Arlo Plastic Housing Replacement: paso 5, imagen 2 de 2
    • Slide the unlocked battery cover forward to remove 2 (3.5mm) screws, that are behind the cover.
  6. Netgear Arlo Plastic Housing Replacement: paso 6, imagen 1 de 1
    • Open the battery cover and remove the 2 (3.5mm") screws from under the cover.
  7. Netgear Arlo Plastic Housing Replacement: paso 7, imagen 1 de 3 Netgear Arlo Plastic Housing Replacement: paso 7, imagen 2 de 3 Netgear Arlo Plastic Housing Replacement: paso 7, imagen 3 de 3
    • Use a plastic opening tool to start separating the plastic housing from the front side of the battery cover.
    • Next, start separating the plastic cover from the rear of the plastic housing, and work your way down the seam line.
    • Make sure the plastics snaps on the front of the plastic get unhooked from the grey plastic ring around the front of the camera.
  8. Netgear Arlo Plastic Housing Replacement: paso 8, imagen 1 de 3 Netgear Arlo Plastic Housing Replacement: paso 8, imagen 2 de 3 Netgear Arlo Plastic Housing Replacement: paso 8, imagen 3 de 3
    • Remove the screw (3.5mm) near the sync button holding the opposite side of the camera on.
    • Remove the second screw (3.5mm) on the back of the camera to remove the second housing.
    • Once the screws are removed use an opening tool to pry back the second plastic mount.
Conclusión
Una persona más ha completado esta guía.
Connor Krampen
Miembro Desde 01/08/18
399 Reputación
3 Guías creadas
Equipo
IUPUI, Team S1-G1, Freund Spring 2018 Miembro de IUPUI, Team S1-G1, Freund Spring 2018
IUPUI-FREUND-S18S1G1
2 Miembros
6 Guías creadas
2 comentarios
Where can I buy replacement parts like a battery cover for Arlo
L R Hardy - Contestar
Note that under the rubber cover shown in step 6 there is a USB-B port.
You can run the Arlo on a USB adapter as well.
You only need to make a hole in the battery lid or 3D print a new cover.
Bas Vijfwinkel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 2,223
