Saltar al contenido principal
Nest x Yale Lock Keypad Replacement
Qué necesitas
  1. Nest x Yale Lock Keypad Replacement, Keypad: paso 1, imagen 1 de 1
    • Unscrew all available screws that you can see from the back.
    • The screws are 0.25 inches phillips screws.
    • Make sure to not lose any of the screws, and keep track of them.
  2. Nest x Yale Lock Keypad Replacement: paso 2, imagen 1 de 1
    • Once you have unscrewed all the screws carefully remove the metal covering.
    • Make sure that the wire safely goes through the hole.
  3. Nest x Yale Lock Keypad Replacement: paso 3, imagen 1 de 1
    • Then once again unscrew the two screws that you see.
    • The screws have a height of 0.2 inches phillips screws.
  4. Nest x Yale Lock Keypad Replacement: paso 4, imagen 1 de 2 Nest x Yale Lock Keypad Replacement: paso 4, imagen 2 de 2
    • Once all screws are unscrewed proceed to tap the screen out of the metal casing.
Conclusión
Equipo
CSU Los Angeles, Team 5-3, Adachi Fall 2022 Miembro de CSU Los Angeles, Team 5-3, Adachi Fall 2022
CSULA-ADACHI-F22S5G3
5 Miembros
5 Guías creadas
Un comentario
Where do you order the touchscreen from?
Mike Turrell - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 300
