Saltar al contenido principal
Motorola RAZR V3i Battery Replacement
Qué necesitas
  1. Motorola RAZR V3i Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Make sure the phone is turned off by holding down the red End Call/Power button until the phone shuts off.
    • If you have a phone case, it has to be removed.
  2. Motorola RAZR V3i Battery Replacement: paso 2, imagen 1 de 3 Motorola RAZR V3i Battery Replacement: paso 2, imagen 2 de 3 Motorola RAZR V3i Battery Replacement: paso 2, imagen 3 de 3
    • Close the phone and find the battery cover button, located on the backside of the phone underneath the hinge.
    • Using your finger, press down on the button to release the back cover. Then, lift the cover and remove it from the phone completely.
    • The flat edge of a credit card or other flat object will also work.
  3. Motorola RAZR V3i Battery Replacement: paso 3, imagen 1 de 3 Motorola RAZR V3i Battery Replacement: paso 3, imagen 2 de 3 Motorola RAZR V3i Battery Replacement: paso 3, imagen 3 de 3
    • Remove the battery by pushing down on it from the top while gently pulling it outwards.
    • Be careful not to use too much force as the battery retaining tab could be damaged.
Linea de Meta
5 personas más completaron esta guía.
Nigel
Miembro Desde 09/06/11
133 Reputación
2 Guías creadas
Equipo
Cuesta, Team 1-5, Zipperian Fall 2011 Miembro de Cuesta, Team 1-5, Zipperian Fall 2011
CUESTA-ZIPPERIAN-F11S1G5
1 Miembro
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 20
Ultimos 30 días: 60
Todo El Tiempo: 7,205
