Saltar al contenido principal
Motorola Moto Z Force Droid Volume Buttons Replacement
Qué necesitas
  1. Motorola Moto Z Force Droid Volume Buttons Replacement, Opening Procedure: paso 1, imagen 1 de 1
    • Apply a heated iOpener to the lower glass panel on the back of the phone for five minutes.
    • The panel is extremely stubborn, and you may need to reheat and reapply the iOpener several times to get the panel warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 2, imagen 1 de 3 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 2, imagen 2 de 3 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 2, imagen 3 de 3
    • Insert an opening pick into the small gap between the rear case and the glass panel.
    • The gap between the panel and the frame is very tight, so it may help to rock or slide the pick back and forth as you push it down into the gap. Alternatively, you can use a thin blade or metal pry tool to lift the panel before prying the rest of the way with a pick, but work slowly and gently to avoid damaging the glass.
    • If you're having trouble inserting your pick, go back a step and heat the panel further. Loosening the panel requires significant heat, but avoid heating the middle of the phone where the battery is.
    • A few drops of high-concentration (at least 90%) isopropyl alcohol applied to the edges of the panel may help to loosen the adhesive as well.
    • Do not pry over the charging port. It is framed with plastic that can be damaged when prying.
    • With tip of the pick under the glass panel, carefully pry upward to slightly separate the rear case and the panel.
  3. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 3, imagen 1 de 3 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 3, imagen 2 de 3 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 3, imagen 3 de 3
    • Slide the pick in between the panel and the rear case.
    • Slide the pick across the length of the panel to slice the adhesive holding it to the rear case.
  4. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 4, imagen 1 de 3 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 4, imagen 2 de 3 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 4, imagen 3 de 3
    • Use the opening pick to carefully pry up the glass panel.
    • Remove the glass panel.
  5. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 5, imagen 1 de 1
    Herramienta utilizada en este paso:
    Tesa 61395 Tape
    $5.99
    Comprar
    • Repeat the previous four heating and removal steps for the upper glass panel.
    • During reassembly, remove leftover adhesive from the panels and the rear case. Then clean those areas with high concentration isopropyl alcohol (greater than 90%) and a lint-free cloth. This will ensure proper adhesion of the panels.
    • Reinstall the panels using a pre-cut adhesive strip or double-sided tape.
  6. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 6, imagen 1 de 1
    • Remove the six 4 mm T3 Torx screws securing the display assembly.
  7. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 7, imagen 1 de 3 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 7, imagen 2 de 3 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 7, imagen 3 de 3
    • Insert the point of a spudger into the hole in the bottom right corner of the rear case.
    • Press the spudger into the hole to separate the display from the rear case.
  8. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 8, imagen 1 de 2 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 8, imagen 2 de 2
    • Use a finger to maintain separation between the display assembly and the rear case while you remove the spudger.
    • Reinsert the flat end of the spudger in the gap between the display assembly and the rear case.
  9. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 9, imagen 1 de 3 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 9, imagen 2 de 3 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 9, imagen 3 de 3
    • Slide the spudger along the side of the phone until you get to the clip securing the display to the rear case.
    • With the spudger right next to the clip, carefully twist the spudger to pry the display away from the rear case and release the clip.
  10. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 10, imagen 1 de 3 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 10, imagen 2 de 3 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 10, imagen 3 de 3
    • Repeat the separation and prying process for the other side of the phone.
    • There is one clip on each side of the phone—make sure both are free before you continue.
    • Be careful not to separate the bottom edge of the display more than 0.5 inches (13 mm) from the rear case. The display cable is still connected and can be damaged if the bottom of the phone is opened too far.
  11. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 11, imagen 1 de 2 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 11, imagen 2 de 2
    • Tilt the top right corner of the display down to disengage one of the tabs that secure the top of the display.
    • Tilt the other corner down next, to disengage the other tab.
    • The display cable is still connected and can be damaged by too much display movement. Tilt the display carefully and stop if you encounter significant resistance.
  12. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 12, imagen 1 de 3 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 12, imagen 2 de 3 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 12, imagen 3 de 3
    • Lift the right edge of the display to hinge the phone open like a book, no more than 45°.
    • Gently lift the display enough to clear the clip from the edge of the rear case, maintaining the 45º angle.
    • Rest the display on the table behind the phone and open to 90º to allow access to the display cable.
  13. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 13, imagen 1 de 2 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 13, imagen 2 de 2
    • Use the flat end of a spudger to lift the display cable connector up out of its socket.
    • Only pry up on the display connector itself and not the socket on the motherboard.
    • At this point during reassembly after the display is connected, turn the phone on and verify that the display functions correctly. If it does, turn the phone off and proceed with reassembly.
    • If it does not work, check that everything is assembled correctly and the connectors are clean. For further troubleshooting, visit our Answers Forum.
  14. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 14, imagen 1 de 1
    Tesa 61395 Tape
    $5.99
    Comprar
    • Remove the display.
    • During reassembly, if you wish to replace the display adhesive strips, first use a spudger to scrape away all the old adhesive, and clean the adhesion area with some high-concentration (at least 90%) isopropyl alcohol on a lint-free cloth.
    • Apply a thin, high-bond tape, like 1 mm Tesa 61395, or a strip from a precut adhesive card, where the old adhesive was.
    • If you're installing a new display assembly, note where the adhesive is on the original assembly and apply adhesive in the same places on the new assembly.
  15. Motorola Moto Z Force Droid Volume Buttons Replacement, Battery: paso 15, imagen 1 de 2 Motorola Moto Z Force Droid Volume Buttons Replacement, Battery: paso 15, imagen 2 de 2
    Comprar
    • Use tweezers to peel the black tape on the top of the battery up from the motherboard EMI shielding.
    • Applying a little heat to the tape before lifting it can help loosen its adhesive.
    • If your replacement battery does not come with this tape, note its position and transfer it to the replacement.
  16. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 16, imagen 1 de 3 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 16, imagen 2 de 3 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 16, imagen 3 de 3
    • In the following steps you will only lift the battery, do not completely remove it—it's still connected to the motherboard.
    • Use tweezers to gently peel the battery pull tab up enough to grab.
    • Use your fingers to grip the battery pull tab and lift the battery up from the phone.
    • If the battery is hard to remove, applying a small amount of high concentration (over 90%) isopropyl alcohol or adhesive remover under the battery may help.
    • If the pull tab breaks, use the flat end of a spudger or an old credit card to pry up carefully on the edges of the battery until it comes loose.
    • The battery can catch fire and/or explode if damaged so be extremely careful.
    • Never reinstall a damaged or deformed battery. Replace the battery.
  17. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 17, imagen 1 de 3 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 17, imagen 2 de 3 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 17, imagen 3 de 3
    • Fold the battery up to reveal the battery connector cover.
    • Use the point of a spudger to pry up and remove the plastic cover from the battery connector.
  18. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 18, imagen 1 de 2 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 18, imagen 2 de 2
    • Use the tip of a spudger to lift the battery connector up out of its socket on the motherboard.
  19. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 19, imagen 1 de 1
    Tesa 61395 Tape
    $5.99
    Comprar
    • Remove the battery.
    • Before installing your replacement, remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
    • Use a few strips of precut adhesive, or other thin double-sided adhesive tape to secure the new battery.
  20. Motorola Moto Z Force Droid Volume Buttons Replacement, Vibrator Motor: paso 20, imagen 1 de 1
    Comprar
    • Use tweezers to flip open the ZIF connector and remove the vibrator ribbon cable.
  21. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 21, imagen 1 de 1
    • Pry the vibrator motor from its position.
  22. Motorola Moto Z Force Droid Volume Buttons Replacement, Volume Buttons: paso 22, imagen 1 de 1
    • Remove SIM card slot by inserting a SIM card ejection tool.
    • Use a paperclip if a SIM card ejection tool is not available.
  23. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 23, imagen 1 de 2 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 23, imagen 2 de 2
    Comprar
    • Remove the golden connector attached to the volume buttons with a pair of tweezers.
  24. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 24, imagen 1 de 2 Motorola Moto Z Force Droid Volume Buttons Replacement: paso 24, imagen 2 de 2
    • Gently lift the motherboard with a pair of tweezers.
    • Do not try to forcefully remove the motherboard.
  25. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 25, imagen 1 de 1
    • Hold the motherboard up.
    • Remove the four T3 screws (2mm) with a T3 screw head.
  26. Motorola Moto Z Force Droid Volume Buttons Replacement: paso 26, imagen 1 de 1
    • Remove the volume button wiring with a pair of tweezers.
    • Remove the volume buttons.
Conclusión
Una persona más ha completado esta guía.
Kenji Fong
Miembro Desde 01/23/18
1,606 Reputación
4 Guías creadas
Equipo
Cal Poly, Team S1-G1, Livingston Winter 2018 Miembro de Cal Poly, Team S1-G1, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G1
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 1,531
