Saltar al contenido principal
Motorola Moto X4 Rear Camera Replacement
Qué necesitas
  1. Motorola Moto X4 Rear Camera Replacement, Heat the screen: paso 1, imagen 1 de 2 Motorola Moto X4 Rear Camera Replacement, Heat the screen: paso 1, imagen 2 de 2
    • Before you begin, turn off your phone.
    • Heat an iOpener and apply it to the left edge of the phone for two minutes.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • As you wait, take note of the the following areas:
    • Display cable—be careful not to slice too deeply near the edge here, or you may damage the display cable.
    • Fingerprint sensor cable—be careful not to slice too deeply near the edge here, or you may damage the fingerprint sensor cable.
  2. Motorola Moto X4 Rear Camera Replacement, Create a gap: paso 2, imagen 1 de 3 Motorola Moto X4 Rear Camera Replacement, Create a gap: paso 2, imagen 2 de 3 Motorola Moto X4 Rear Camera Replacement, Create a gap: paso 2, imagen 3 de 3
    • Apply a suction cup to the screen, as close to the heated edge as possible.
    • Pull on the suction cup with strong, steady force to create a gap in the seam.
    • Insert the point of an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
  3. Motorola Moto X4 Rear Camera Replacement, Slice the screen adhesive: paso 3, imagen 1 de 3 Motorola Moto X4 Rear Camera Replacement, Slice the screen adhesive: paso 3, imagen 2 de 3 Motorola Moto X4 Rear Camera Replacement, Slice the screen adhesive: paso 3, imagen 3 de 3
    • Slide the opening pick along the edge to slice through the adhesive.
    • Leave an opening pick in the seam to prevent the adhesive from re-sealing.
  4. Motorola Moto X4 Rear Camera Replacement: paso 4, imagen 1 de 3 Motorola Moto X4 Rear Camera Replacement: paso 4, imagen 2 de 3 Motorola Moto X4 Rear Camera Replacement: paso 4, imagen 3 de 3
    • Heat the top edge of the phone with an iOpener.
    • Carefully slice around the corner and through the top edge to separate the adhesive.
  5. Motorola Moto X4 Rear Camera Replacement: paso 5, imagen 1 de 3 Motorola Moto X4 Rear Camera Replacement: paso 5, imagen 2 de 3 Motorola Moto X4 Rear Camera Replacement: paso 5, imagen 3 de 3
    • Heat the screen's right edge with an iOpener.
    • Be careful not to slice too deeply near the cables to avoid damaging them.
    • Use an opening pick to slice along the right edge to separate the adhesive.
  6. Motorola Moto X4 Rear Camera Replacement: paso 6, imagen 1 de 2 Motorola Moto X4 Rear Camera Replacement: paso 6, imagen 2 de 2
    • Repeat the previous steps to heat and slice the bottom edge of the phone.
  7. Motorola Moto X4 Rear Camera Replacement: paso 7, imagen 1 de 2 Motorola Moto X4 Rear Camera Replacement: paso 7, imagen 2 de 2
    • Do not try to remove the screen yet—it is still attached to the phone by delicate flex cables.
    • Carefully lift up the left edge of the screen and cut away remaining adhesives with an opening pick.
  8. Motorola Moto X4 Rear Camera Replacement: paso 8, imagen 1 de 1
    • Swing open the screen and prop it up with a small box as you work on disconnecting the flex cables.
    • During reassembly, this is a good time to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
  9. Motorola Moto X4 Rear Camera Replacement, Detach the fingerprint sensor cable: paso 9, imagen 1 de 2 Motorola Moto X4 Rear Camera Replacement, Detach the fingerprint sensor cable: paso 9, imagen 2 de 2
    • Slide the point of a spudger underneath the fingerprint sensor cable and gently pry up to loosen the cable from the phone.
    • Do not pull on the cable. It is still attached to the phone by a delicate ZIF socket.
  10. Motorola Moto X4 Rear Camera Replacement, Disconnect the fingerprint sensor: paso 10, imagen 1 de 3 Motorola Moto X4 Rear Camera Replacement, Disconnect the fingerprint sensor: paso 10, imagen 2 de 3 Motorola Moto X4 Rear Camera Replacement, Disconnect the fingerprint sensor: paso 10, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use the point of a spudger to flip up the lock bar on the fingerprint sensor's ZIF socket, near the bottom right of the phone.
    • Use tweezers to carefully slide the fingerprint sensor cable out of the socket.
  11. Motorola Moto X4 Rear Camera Replacement, Disconnect the display cable: paso 11, imagen 1 de 3 Motorola Moto X4 Rear Camera Replacement, Disconnect the display cable: paso 11, imagen 2 de 3 Motorola Moto X4 Rear Camera Replacement, Disconnect the display cable: paso 11, imagen 3 de 3
    • Use an opening tool to flip up the wide lock bar on the display cable's ZIF socket, near the top right of the phone.
    • Use tweezers to carefully slide the display cable out of the ZIF socket.
  12. Motorola Moto X4 Rear Camera Replacement, Remove the screen: paso 12, imagen 1 de 2 Motorola Moto X4 Rear Camera Replacement, Remove the screen: paso 12, imagen 2 de 2
    • Remove the screen.
    • During reassembly, follow this guide to clean the existing adhesive off and install custom-cut adhesives for your phone.
  13. Motorola Moto X4 Rear Camera Replacement, Unscrew the midframe: paso 13, imagen 1 de 2 Motorola Moto X4 Rear Camera Replacement, Unscrew the midframe: paso 13, imagen 2 de 2
    • Remove the following twenty screws securing the midframe:
    • Eleven silver 2.7 mm-long T3 screws
    • Nine black 3.6 mm-long T4 screws
    • The midframe is still held in place by clips.
  14. Motorola Moto X4 Rear Camera Replacement, Loosen the midframe: paso 14, imagen 1 de 3 Motorola Moto X4 Rear Camera Replacement, Loosen the midframe: paso 14, imagen 2 de 3 Motorola Moto X4 Rear Camera Replacement, Loosen the midframe: paso 14, imagen 3 de 3
    • The next few steps show how to loosen the midframe clips.
    • Insert the flat end of a spudger under the right edge of the metal midframe and pry up to loosen the midframe.
    • Insert an opening pick in the edge to hold the midframe in place.
  15. Motorola Moto X4 Rear Camera Replacement: paso 15, imagen 1 de 2 Motorola Moto X4 Rear Camera Replacement: paso 15, imagen 2 de 2
    • Insert the flat end of a spudger under the lower right edge of the midframe and pry up to release the midframe clip.
  16. Motorola Moto X4 Rear Camera Replacement: paso 16, imagen 1 de 3 Motorola Moto X4 Rear Camera Replacement: paso 16, imagen 2 de 3 Motorola Moto X4 Rear Camera Replacement: paso 16, imagen 3 de 3
    • Grasp the lower edge of the midframe and pull the edge slightly to the right, to clear the metal midframe clip.
  17. Motorola Moto X4 Rear Camera Replacement: paso 17, imagen 1 de 2 Motorola Moto X4 Rear Camera Replacement: paso 17, imagen 2 de 2
    • Insert the point of an opening pick under the top left corner of the midframe and twist slightly to release the top clip.
  18. Motorola Moto X4 Rear Camera Replacement, Remove the midframe: paso 18, imagen 1 de 3 Motorola Moto X4 Rear Camera Replacement, Remove the midframe: paso 18, imagen 2 de 3 Motorola Moto X4 Rear Camera Replacement, Remove the midframe: paso 18, imagen 3 de 3
    • Remove the midframe.
    • To reinstall the midframe:
    • Align the the midframe's top edge to the phone and press it into position.
    • Shift the bottom edge slightly to the left, to maneuver the left metal midframe clip underneath the phone edge.
    • Press the midframe's bottom edge into position.
  19. Motorola Moto X4 Rear Camera Replacement, Disconnect the battery: paso 19, imagen 1 de 2 Motorola Moto X4 Rear Camera Replacement, Disconnect the battery: paso 19, imagen 2 de 2
    • Insert the point of a spudger underneath the top edge of the battery connector.
    • Be careful not to dislodge the small surface-mounted components surrounding the socket.
    • Gently pry up the connector to disconnect the battery.
  20. Motorola Moto X4 Rear Camera Replacement: paso 20, imagen 1 de 3 Motorola Moto X4 Rear Camera Replacement: paso 20, imagen 2 de 3 Motorola Moto X4 Rear Camera Replacement: paso 20, imagen 3 de 3
    • To re-connect the battery, align the connector on top of the socket, and press it down with your finger or a spudger.
  21. Motorola Moto X4 Rear Camera Replacement, Rear Camera: paso 21, imagen 1 de 2 Motorola Moto X4 Rear Camera Replacement, Rear Camera: paso 21, imagen 2 de 2
    • Using a T3 Torx screwdriver, remove both 1cm screws. To do this, insert the screwdriver into the head of the screw, then turn counter-clockwise.
  22. Motorola Moto X4 Rear Camera Replacement: paso 22, imagen 1 de 2 Motorola Moto X4 Rear Camera Replacement: paso 22, imagen 2 de 2
    Comprar
    • Use the tweezers to gently lift the rear camera up and out of your Moto X4.
Conclusión
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto X4 Answers community for help.
3 personas más completaron esta guía.
Brian Buchanan
Miembro Desde 01/24/18
1,047 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S18-G4, Livingston Winter 2018 Miembro de Cal Poly, Team S18-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G4
4 Miembros
13 Guías creadas
Un comentario
I'm up based anyone know where I can get a replacement camera
Ashley Fall - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 3,404
