Introducción
The Motorola Moto G6 features a headphone jack used to connect various types of headphones and earbuds to the device. If the headphone jack is damaged, the connected device may not play clearly, or with a low volume. A headphone jack replacement may be required.
This guide teaches how to perform a headphone jack replacement. No repair experience is required. However, this replacement will require tools to pry the back shell open, unscrew plates within the device, remove interior pieces, and solder inside of the device. The specific device model in this guide is XT1925-12. Other model numbers include: XT1925-4, XT1925-5, XT1925-6, and XT1925DL.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Before beginning the repair, make sure the device is turned off and disconnected from an external power source. Gather the suggested tools listed below and a new Motorola Moto G6 headphone jack
Qué necesitas
If possible, drain the battery before disassembly. When the battery is charged, there's an increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
Apply a suction cup to the bottom edge of the rear glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the frame.
If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
Insert an opening pick into the gap you created under the rear glass.
Use a pair of tweezers to carefully peel up the black tape covering the battery.
Remove the tape.
Use a Phillips driver to remove seventeen screws securing the plastic cover:
Eleven grey 3 mm-long screws
Five black 2.5 mm-long screws
One silver 3.5 mm-long screw
Using the iFixit opening tool, pop up the three press-fit connectors in the bottom right corner of the motherboard.
Use the opening tool to disconnect the press-fit connection on the top left of the motherboard, similar to the previous step.
Use either your fingernail or tweezers to pull the orange boxed connector out. Unlike the other connections, this one is pulled down and not up from the device.
Locate the headphone jack on the bottom right side of the mother board.
Using a soldering iron, solder the five contact points and remove the charging port from your device.
4 personas más completaron esta guía.
