Saltar al contenido principal
Motorola Moto G3 Battery Replacement
Guía Archivada
Esta guía se mantiene únicamente para fines históricos. Utiliza la última versión de la guía para llevar a cabo tu reparación.
Qué necesitas
  1. Motorola Moto G3 Battery Replacement, Prerequisite Guide: paso 1, imagen 1 de 2 Motorola Moto G3 Battery Replacement, Prerequisite Guide: paso 1, imagen 2 de 2
    • Use the plastic opening tool to open the back cover as shown in the photo.
  2. Motorola Moto G3 Battery Replacement: paso 2, imagen 1 de 1
    • Heat an iOpener in the microwave for 30 seconds.
    • Place the heated iOpener on all four edges of the screen for approximately 2 minutes.
  3. Motorola Moto G3 Battery Replacement: paso 3, imagen 1 de 1
    • Apply the plastic opening tool on the edge of the screen near the front camera.
    • After creating enough space, allow the opening tool to be inserted on the side of the phone.
    • Create another space on the other side of the screen.
    • Leave the opening tool inserted.
    • Carefully apply the larger plastic opening tool by sliding it through the longer edge of the screen.
  4. Motorola Moto G3 Battery Replacement: paso 4, imagen 1 de 3 Motorola Moto G3 Battery Replacement: paso 4, imagen 2 de 3 Motorola Moto G3 Battery Replacement: paso 4, imagen 3 de 3
    • A strip will be attached to the motherboard as shown.
    • Using tweezers, carefully detach the strip from the motherboard.
  5. Motorola Moto G3 Battery Replacement, Battery: paso 5, imagen 1 de 3 Motorola Moto G3 Battery Replacement, Battery: paso 5, imagen 2 de 3 Motorola Moto G3 Battery Replacement, Battery: paso 5, imagen 3 de 3
    • With a T4 screwdriver, remove the 10 "yellow" 2mm screws and 4 "black" 2mm screws.
  6. Motorola Moto G3 Battery Replacement: paso 6, imagen 1 de 2 Motorola Moto G3 Battery Replacement: paso 6, imagen 2 de 2
    • Use the metal spudger and lift the back cover on the bottom side of the phone (this is attached to the motherboard).
  7. Motorola Moto G3 Battery Replacement: paso 7, imagen 1 de 1
    • Remove the red and black battery cable from its port using tweezers.
  8. Motorola Moto G3 Battery Replacement: paso 8, imagen 1 de 2 Motorola Moto G3 Battery Replacement: paso 8, imagen 2 de 2
    • Use the same tweezers to remove the red battery from where it is placed.
Conclusión
4 personas más completaron esta guía.
Irkan Notta
Miembro Desde 03/19/18
1,034 Reputación
7 Guías creadas
Equipo
Baylor, Team S5-G3, Williams Spring 2018 Miembro de Baylor, Team S5-G3, Williams Spring 2018
BU-WILLIAMS-S18S5G3
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 4
Todo El Tiempo: 969
