Saltar al contenido principal
Motorola Moto E4 Plus Power and Volume Buttons Replacement
Qué necesitas
  1. Motorola Moto E4 Plus Power and Volume Buttons Replacement, Remove the back cover: paso 1, imagen 1 de 3 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Remove the back cover: paso 1, imagen 2 de 3 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Remove the back cover: paso 1, imagen 3 de 3
    • Power off your phone before beginning disassembly.
    • Insert the edge of the spudger into the notch on the bottom right corner of the phone.
    • Twist the spudger to start releasing the back cover from the phone.
    • Slide the spudger along the bottom edge to separate the back cover from the phone.
  2. Motorola Moto E4 Plus Power and Volume Buttons Replacement: paso 2, imagen 1 de 2 Motorola Moto E4 Plus Power and Volume Buttons Replacement: paso 2, imagen 2 de 2
    • Lift the phone unit out of the back cover.
  3. Motorola Moto E4 Plus Power and Volume Buttons Replacement, Remove the midframe screws: paso 3, imagen 1 de 1
    • Remove the nineteen 3.2 mm long T3 screws securing the plastic midframe.
  4. Motorola Moto E4 Plus Power and Volume Buttons Replacement, Release the midframe clips: paso 4, imagen 1 de 2 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Release the midframe clips: paso 4, imagen 2 de 2
    • The plastic midframe is still held in place with clips.
    • Insert the flat end of a spudger into the midframe seam at the bottom left corner of the phone (near the microphone hole).
    • Twist the spudger to release the plastic clip.
    • Repeat the process for the clip near the top right corner of the phone.
  5. Motorola Moto E4 Plus Power and Volume Buttons Replacement, Remove the midframe: paso 5, imagen 1 de 2 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Remove the midframe: paso 5, imagen 2 de 2
    • Lift the bottom edge of the plastic midframe upwards until the clips along the top edge release.
    • Remove the plastic midframe.
    • To reattach the plastic midframe, line up the midframe to the phone and squeeze along the edges to engage the clips.
  6. Motorola Moto E4 Plus Power and Volume Buttons Replacement, Disconnect the battery: paso 6, imagen 1 de 2 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Disconnect the battery: paso 6, imagen 2 de 2
    • Use the point of a spudger to pry up and disconnect the battery connector from its motherboard socket.
  7. Motorola Moto E4 Plus Power and Volume Buttons Replacement, Battery adhesives: paso 7, imagen 1 de 3 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Battery adhesives: paso 7, imagen 2 de 3 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Battery adhesives: paso 7, imagen 3 de 3
    • If your battery has two black tabs near the bottom corners, the battery is held in place by stretch-release adhesives. If that's the case, follow this guide instead to complete your battery replacement.
    • Before you begin prying, note that the battery is held in place by two adhesive strips.
  8. Motorola Moto E4 Plus Power and Volume Buttons Replacement, Loosen the battery: paso 8, imagen 1 de 2 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Loosen the battery: paso 8, imagen 2 de 2
    • Insert an opening pick into the top right edge of the battery.
    • Push the opening pick in carefully until half of the pick is under the battery.
  9. Motorola Moto E4 Plus Power and Volume Buttons Replacement: paso 9, imagen 1 de 1
    • Fill a plastic dropper or syringe with high concentration isopropyl alcohol and apply a few drops of alcohol along the right edge of the battery.
    • Tilt the edge up slightly for a minute to allow the isopropyl alcohol to soften the adhesive.
  10. Motorola Moto E4 Plus Power and Volume Buttons Replacement: paso 10, imagen 1 de 2 Motorola Moto E4 Plus Power and Volume Buttons Replacement: paso 10, imagen 2 de 2
    • As you slice through the adhesive with the opening pick, try your best not to bend the battery pack. Soft shell lithium-ion batteries are highly susceptible to damage and can ignite when compromised.
    • Insert another opening pick into the right edge, near the first opening pick.
    • Slide the opening pick down along the right edge to loosen the right adhesive strip.
    • If the slicing feels difficult, apply a few more drops of isopropyl alcohol into the edge, wait a minute for it to seep in, and try again.
  11. Motorola Moto E4 Plus Power and Volume Buttons Replacement: paso 11, imagen 1 de 1
    • Insert an opening pick into the bottom left edge of the battery.
    • Push the opening pick until it is halfway under the battery.
    • Apply isopropyl alcohol along the left edge and let it sit for a minute to weaken the adhesive.
  12. Motorola Moto E4 Plus Power and Volume Buttons Replacement: paso 12, imagen 1 de 2 Motorola Moto E4 Plus Power and Volume Buttons Replacement: paso 12, imagen 2 de 2
    • Grasp the battery along the right corners and slowly lift the right edge upwards.
    • If the battery begins to bend significantly, stop and re-apply more isopropyl alcohol to the left adhesive strip.
  13. Motorola Moto E4 Plus Power and Volume Buttons Replacement: paso 13, imagen 1 de 1
    • Remove the battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • To install a replacement battery:
    • Remove the old adhesive from the phone frame.
    • Apply new adhesive in the same general area as the old adhesive.
    • Lay the battery lightly in place. Check that the battery connector is properly aligned with its motherboard socket.
    • Press the battery firmly into the phone for thirty seconds.
  14. Motorola Moto E4 Plus Power and Volume Buttons Replacement, Disconnect the display cable: paso 14, imagen 1 de 2 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Disconnect the display cable: paso 14, imagen 2 de 2
    • Use the point of a spudger to pry up and disconnect the display cable from its motherboard socket, near the bottom left corner of the motherboard.
  15. Motorola Moto E4 Plus Power and Volume Buttons Replacement, Disconnect the antenna cable: paso 15, imagen 1 de 2 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Disconnect the antenna cable: paso 15, imagen 2 de 2
    • Use the point of a spudger to pry up and disconnect the antenna cable from its motherboard socket.
  16. Motorola Moto E4 Plus Power and Volume Buttons Replacement, Disconnect the interconnect cable: paso 16, imagen 1 de 2 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Disconnect the interconnect cable: paso 16, imagen 2 de 2
    • Use the point of a spudger to pry up and disconnect the interconnect cable from its motherboard socket.
  17. Motorola Moto E4 Plus Power and Volume Buttons Replacement, Remove the motherboard screws: paso 17, imagen 1 de 1
    • Remove the two black 3.2 mm long T3 screws securing the motherboard.
  18. Motorola Moto E4 Plus Power and Volume Buttons Replacement, Remove the motherboard: paso 18, imagen 1 de 2 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Remove the motherboard: paso 18, imagen 2 de 2
    • Grasp the motherboard by the top corners and lift it out of the phone.
    • Remove the motherboard.
  19. Motorola Moto E4 Plus Power and Volume Buttons Replacement, Power and Volume Buttons: paso 19, imagen 1 de 3 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Power and Volume Buttons: paso 19, imagen 2 de 3 Motorola Moto E4 Plus Power and Volume Buttons Replacement, Power and Volume Buttons: paso 19, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use the Precision Tweezer to detach the Power and Volume Buttons Flex. Start at the lip of the phone, as seen in Image 2, and lift up. Slide the precision tweezers under the power and volume buttons flex until you reach the gold plated section, detaching it from the phone.
  20. Motorola Moto E4 Plus Power and Volume Buttons Replacement: paso 20, imagen 1 de 2 Motorola Moto E4 Plus Power and Volume Buttons Replacement: paso 20, imagen 2 de 2
    • Use the Plastic Spudger to finish lifting the volume and power buttons flex from the base of the phone.
  21. Motorola Moto E4 Plus Power and Volume Buttons Replacement: paso 21, imagen 1 de 3 Motorola Moto E4 Plus Power and Volume Buttons Replacement: paso 21, imagen 2 de 3 Motorola Moto E4 Plus Power and Volume Buttons Replacement: paso 21, imagen 3 de 3
    • Use the Precision Tweezers to pull the volume and power buttons off of the side of the phone, as seen in the pictures. It is all one piece and will be pulled off together.
    • Do not be afraid to pull with some force to remove the buttons. The buttons are connected by an adhesive but can be pulled off easily, be confident in the strength of the buttons.
  22. Motorola Moto E4 Plus Power and Volume Buttons Replacement: paso 22, imagen 1 de 1
    • This is the result of removing the volume and power buttons flex from the phone.
Conclusión
4 personas más completaron esta guía.
Jack Haseman
Miembro Desde 03/19/18
1,396 Reputación
6 Guías creadas
Equipo
Baylor, Team S3-G2, Williams Spring 2018 Miembro de Baylor, Team S3-G2, Williams Spring 2018
BU-WILLIAMS-S18S3G2
4 Miembros
13 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 53
Todo El Tiempo: 4,533
