Saltar al contenido principal
Motorola MBP33SBU Baby Unit Speaker Replacement
Qué necesitas
  1. Motorola MBP33SBU Baby Unit Speaker Replacement, Baby Unit Speaker: paso 1, imagen 1 de 3 Motorola MBP33SBU Baby Unit Speaker Replacement, Baby Unit Speaker: paso 1, imagen 2 de 3 Motorola MBP33SBU Baby Unit Speaker Replacement, Baby Unit Speaker: paso 1, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Using precision tweezers, remove the (4) four rubber feet from the bottom of the baby unit.
    • Using a Phillips #1 screwdriver remove the 9.5mm screws that were under the rubber feet.
    • Open the base of the baby unit.
  2. Motorola MBP33SBU Baby Unit Speaker Replacement: paso 2, imagen 1 de 3 Motorola MBP33SBU Baby Unit Speaker Replacement: paso 2, imagen 2 de 3 Motorola MBP33SBU Baby Unit Speaker Replacement: paso 2, imagen 3 de 3
    • Using the Phillips #1 screwdriver remove the 9.5mm washer head screws holding the speaker in place.
    • Gently lift the speaker by the wires from its plastic base.
  3. Motorola MBP33SBU Baby Unit Speaker Replacement: paso 3, imagen 1 de 2 Motorola MBP33SBU Baby Unit Speaker Replacement: paso 3, imagen 2 de 2
    • Desolder the wires connecting the speaker to the circuit board.
    • Beware of overheating, the soldering kit is capable of damaging the circuit board.
    • Beware of the potential for personal injury from heated metals.
    • For soldering procedures please refer to iFixit's guide to Soldering Skills.
Conclusión
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 12
Todo El Tiempo: 2,041
