Saltar al contenido principal
Motorola Droid X Rear Housing Replacement
Qué necesitas
  1. Motorola Droid X Rear Housing Replacement, Rear Housing: paso 1, imagen 1 de 1
    • First begin by sliding down the battery door, and place that to the side.
  2. Motorola Droid X Rear Housing Replacement: paso 2, imagen 1 de 2 Motorola Droid X Rear Housing Replacement: paso 2, imagen 2 de 2
    • Pull the battery tab up, and remove the battery from the phone.
  3. Motorola Droid X Rear Housing Replacement: paso 3, imagen 1 de 1
    • Remove the two T5 screws as shown by the markers.
  4. Motorola Droid X Rear Housing Replacement: paso 4, imagen 1 de 2 Motorola Droid X Rear Housing Replacement: paso 4, imagen 2 de 2
    • Flip the phone over to the front, and slide an opening tool as shown between the metal housing & the plastic piece covering the lower portion of the phone by the microphone.
  5. Motorola Droid X Rear Housing Replacement: paso 5, imagen 1 de 1
    • Now do the same to the top of the phone with your opening tool as shown to remove the other plastic piece covering the top of the phone.
  6. Motorola Droid X Rear Housing Replacement: paso 6, imagen 1 de 2 Motorola Droid X Rear Housing Replacement: paso 6, imagen 2 de 2
    • Now with both of the plastic covers removed, remove the 4 silver T5 screws on the top and bottom of the unit as shown.
  7. Motorola Droid X Rear Housing Replacement: paso 7, imagen 1 de 3 Motorola Droid X Rear Housing Replacement: paso 7, imagen 2 de 3 Motorola Droid X Rear Housing Replacement: paso 7, imagen 3 de 3
    • Starting on the top right side of the phone, run your opening tool down the side and all the way around with slight force to begin to separate the back housing from the front assembly.
    • Look at the two pictures showing the clips to help you know where they are located.
  8. Motorola Droid X Rear Housing Replacement: paso 8, imagen 1 de 1
    • You can easily release the two clips on the right side (nearest the headphone jack) by pressing in the black plastic tabs inside the metal clips. The torx screwdriver you used earlier works well for this.
  9. Motorola Droid X Rear Housing Replacement: paso 9, imagen 1 de 1
    • Congratulations! You have now successfully removed your back housing from your Droid X!
Conclusión
7 personas más completaron esta guía.
Josh Forester
Miembro Desde 11/28/10
2,505 Reputación
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 5,605
