Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Motorola Droid Turbo Dual LED Flash Board Replacement
Qué necesitas
    1. Motorola Droid Turbo Dual LED Flash Board Replacement, Rear Case: paso 1, imagen 1 de 1
      • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
      Pregunta a FixBot
      Agregar Comentario
    2. Motorola Droid Turbo Dual LED Flash Board Replacement: paso 2, imagen 1 de 2 Motorola Droid Turbo Dual LED Flash Board Replacement: paso 2, imagen 2 de 2
      • Use a plastic opening tool to pry the rear case off of the rest of the device.
      • Remove the rear case.
      • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
      Pregunta a FixBot
      Agregar Comentario
    1. Motorola Droid Turbo Dual LED Flash Board Replacement, Dual LED Flash Board: paso 3, imagen 1 de 2 Motorola Droid Turbo Dual LED Flash Board Replacement, Dual LED Flash Board: paso 3, imagen 2 de 2
      • Use a Jimmy to separate the dual LED flash board from the rear case.
      • The board is secured with some light adhesive, so some force may be required.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Geoff Wacker
Miembro Desde 09/30/13
93,084 Reputación
88 Guías creadas
1Guía Comentario
Gostaria se possível alguem tenha o manual de serviço do Moto maxx XT 1225 ou 1254. Porf favor , ddani8260@gmail.com
Daniel Gomes - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 28
Ultimos 30 días: 101
Todo El Tiempo: 1,555
