Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Motorola Droid Turbo Battery Replacement
Qué necesitas
  1. Motorola Droid Turbo Battery Replacement, Rear Case: paso 1, imagen 1 de 1
    • Prepare an iOpener and lay it over the rear case to soften the adhesive on securing the rear case to the phone.
    Pregunta a FixBot
    Agregar Comentario
  2. Motorola Droid Turbo Battery Replacement: paso 2, imagen 1 de 2 Motorola Droid Turbo Battery Replacement: paso 2, imagen 2 de 2
    • Use a plastic opening tool to pry the rear case off of the rest of the device.
    • Remove the rear case.
    • The wireless charging coil may try to stick to the rear case, so make sure to remove it from the case before fully separating the rear case from the rest of the device.
    Pregunta a FixBot
    Agregar Comentario
  3. Motorola Droid Turbo Battery Replacement, Midframe: paso 3, imagen 1 de 1
    • Remove the midframe bezel.
    Pregunta a FixBot
    Agregar Comentario
  4. Motorola Droid Turbo Battery Replacement: paso 4, imagen 1 de 1
    • Remove the four Torx T5 screws securing the midframe plate.
    Pregunta a FixBot
    Agregar Comentario
  5. Motorola Droid Turbo Battery Replacement: paso 5, imagen 1 de 1
    • Remove the midframe.
    Pregunta a FixBot
    Agregar Comentario
  6. Motorola Droid Turbo Battery Replacement, Battery: paso 6, imagen 1 de 2 Motorola Droid Turbo Battery Replacement, Battery: paso 6, imagen 2 de 2
    • Use the point of a spudger to pop up the battery connector.
    Pregunta a FixBot
    Agregar Comentario
  7. Motorola Droid Turbo Battery Replacement: paso 7, imagen 1 de 2 Motorola Droid Turbo Battery Replacement: paso 7, imagen 2 de 2
    • Fold the wireless charging coil away from the battery.
    Pregunta a FixBot
    Agregar Comentario
  8. Motorola Droid Turbo Battery Replacement: paso 8, imagen 1 de 2 Motorola Droid Turbo Battery Replacement: paso 8, imagen 2 de 2
    • Use a spudger to gently pry the battery up from the rest of the device.
    • The battery is secured with some moderate adhesive, so some force may be necessary.
    Pregunta a FixBot
    Agregar Comentario
Conclusión
60 personas más completaron esta guía.
Equipo
USF Tampa, Team 15-5, Remmell Spring 2016 Miembro de USF Tampa, Team 15-5, Remmell Spring 2016
USFT-REMMELL-S16S15G5
Miembros de 3
10 Guías creadas
34Guía Comentarios
The screws that attach the black plastic in step 3 are NOT #2 phillips. This is reasonably obvious from the photo but the misleading caption should be changed. They are T5 Torx bit screws. Also, the plastic camera sub assembly in step 4 has 3 small t shaped tabs that shear if you pry it away from the phone. I could not see a way to remove the sub assembly without damaging the tabs so the 4 T5 screws will have to keep it in place from now on.
Jeffrey Sauter - Contestar Compartir
Hey Jeffrey! Thanks for the heads up. Feel free to edit the guide steps as you see fit by selecting Edit in the top right corner of the guide step in question. We changed the permissions so you should be able to edit the text. Thanks again for contributing!
Kelsea Weber - Contestar Compartir
Do you need to apply fresh adhesive when re-assembling?
Richard Klein - Contestar Compartir
Do you need to apply adhesive when re assembling?
ben_martell - Contestar Compartir
the adhesive is 3 narrow pieces of double sided tape. You can carefully peel it off the old battery and reuse it. I don't see where it's absolutely necessary though. The battery isn't going to move around after the phone is put back together.
Mike Mangiaruca - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 64
Todo El Tiempo: 87,873
