Saltar al contenido principal
Motorola Droid RAZR M Battery Replacement
Qué necesitas
  1. Motorola Droid RAZR M Battery Replacement, Front Assembly: paso 1, imagen 1 de 3 Motorola Droid RAZR M Battery Replacement, Front Assembly: paso 1, imagen 2 de 3 Motorola Droid RAZR M Battery Replacement, Front Assembly: paso 1, imagen 3 de 3
    • Open the small latch on the left side of the device by lifting gently with your finger, exposing the SIM card and microSD card slots.
    • If either of these cards are present, remove them to prevent damaging them while taking apart the phone. Our device does not have either.
    • Close the latch once the two cards are removed.
  2. Motorola Droid RAZR M Battery Replacement: paso 2, imagen 1 de 3 Motorola Droid RAZR M Battery Replacement: paso 2, imagen 2 de 3 Motorola Droid RAZR M Battery Replacement: paso 2, imagen 3 de 3
    • Remove the six 4mm T3 Torx screws. There are 3 on each side of the device.
  3. Motorola Droid RAZR M Battery Replacement: paso 3, imagen 1 de 3 Motorola Droid RAZR M Battery Replacement: paso 3, imagen 2 de 3 Motorola Droid RAZR M Battery Replacement: paso 3, imagen 3 de 3
    • Run the plastic opening tool under the bottom edge of the phone to detach the small plastic cover below the Verizon logo.
    • It will take some force to remove this piece. Work around the bottom corners to unlatch the two hooks holding the piece in place.
    • The small plastic hooks can break during removal. Be careful that you don't damage them, but it will take some force to get them undone.
    • Once the plastic cover is detached, pull the piece away with your fingers.
  4. Motorola Droid RAZR M Battery Replacement: paso 4, imagen 1 de 2 Motorola Droid RAZR M Battery Replacement: paso 4, imagen 2 de 2
    • Remove the three T4 Torx screws. There are three at the bottom of the device.
  5. Motorola Droid RAZR M Battery Replacement: paso 5, imagen 1 de 3 Motorola Droid RAZR M Battery Replacement: paso 5, imagen 2 de 3 Motorola Droid RAZR M Battery Replacement: paso 5, imagen 3 de 3
    • Using the plastic opening tool, peel away the silver Motorola plate at the top of the phone. There is a fair amount of adhesive underneath, so you may have to pry it from a few different angles.
    • As soon as you can get your finger underneath, pull away the silver plate.
  6. Motorola Droid RAZR M Battery Replacement: paso 6, imagen 1 de 2 Motorola Droid RAZR M Battery Replacement: paso 6, imagen 2 de 2
    • Remove the two 7mm T4 Torx screws at the top of the device.
  7. Motorola Droid RAZR M Battery Replacement: paso 7, imagen 1 de 3 Motorola Droid RAZR M Battery Replacement: paso 7, imagen 2 de 3 Motorola Droid RAZR M Battery Replacement: paso 7, imagen 3 de 3
    • When you detach the front from the back, don't pull the two pieces entirely apart. There is a flat orange wire that connects the two pieces that will be disconnected in the next step.
    • Snap apart the two internal clips located on the top corners of the device, and the two clips in the bottom corners.
    • Run the plastic opening tool around the edge of the entire device to pry apart the front of the phone from the back.
    • There is a small black plastic piece located at the bottom of the front assembly. Do not worry if the strip falls off; just simply snap it back on and proceed.
  8. Motorola Droid RAZR M Battery Replacement: paso 8, imagen 1 de 3 Motorola Droid RAZR M Battery Replacement: paso 8, imagen 2 de 3 Motorola Droid RAZR M Battery Replacement: paso 8, imagen 3 de 3
    • Like a clamshell, slowly open the device from the top. Open the remainder of the device slowly while being mindful of the flat orange wire that connects the motherboard to the front assembly.
    • Undo the snap connection in the lower left corner by inserting the plastic opening tool under the end of the orange wire connected to the motherboard. Lift gently.
    • Once the snap connection is undone, pull apart the front assembly from the rest of the phone.
  9. Motorola Droid RAZR M Battery Replacement, Motherboard: paso 9, imagen 1 de 2 Motorola Droid RAZR M Battery Replacement, Motherboard: paso 9, imagen 2 de 2
    • Remove the six 4mm T5 Torx screws located along the outer edge of the motherboard.
  10. Motorola Droid RAZR M Battery Replacement: paso 10, imagen 1 de 2 Motorola Droid RAZR M Battery Replacement: paso 10, imagen 2 de 2
    • Disconnect the snap connection in the lower left corner by prying underneath using the plastic opening tool.
  11. Motorola Droid RAZR M Battery Replacement: paso 11, imagen 1 de 2 Motorola Droid RAZR M Battery Replacement: paso 11, imagen 2 de 2
    • Disconnect the snap connection in the upper left corner by prying underneath using the plastic opening tool.
    • As you undo the snap connection, pull the rear facing camera off completely. It will slide out of its slot in the motherboard.
  12. Motorola Droid RAZR M Battery Replacement: paso 12, imagen 1 de 2 Motorola Droid RAZR M Battery Replacement: paso 12, imagen 2 de 2
    • Disconnect the snap connection in the upper right corner by prying underneath using the plastic opening tool.
  13. Motorola Droid RAZR M Battery Replacement: paso 13, imagen 1 de 3 Motorola Droid RAZR M Battery Replacement: paso 13, imagen 2 de 3 Motorola Droid RAZR M Battery Replacement: paso 13, imagen 3 de 3
    • By inserting the plastic opening tool between the motherboard and rear casing, lift the bottom of the motherboard from the rear casing.
    • Use your fingers to gently pull the motherboard down and out of the rear casing.
  14. Motorola Droid RAZR M Battery Replacement, Battery: paso 14, imagen 1 de 3 Motorola Droid RAZR M Battery Replacement, Battery: paso 14, imagen 2 de 3 Motorola Droid RAZR M Battery Replacement, Battery: paso 14, imagen 3 de 3
    • Peel back the plastic from the face of the battery.
  15. Motorola Droid RAZR M Battery Replacement: paso 15, imagen 1 de 3 Motorola Droid RAZR M Battery Replacement: paso 15, imagen 2 de 3 Motorola Droid RAZR M Battery Replacement: paso 15, imagen 3 de 3
    • Pull up on the plastic to lift the battery out of the rear assembly casing.
    • There is adhesive securing the battery so you will need to apply a good amount of force.
    • Hold down the left edge of the rear assembly casing as you pull the battery out.
Conclusión
11 personas más completaron esta guía.
Thomas Fenner
Miembro Desde 04/22/15
488 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 15-1, Amido Spring 2015 Miembro de Cal Poly, Team 15-1, Amido Spring 2015
CPSU-AMIDO-S15S15G1
4 Miembros
14 Guías creadas
6 comentarios
Thank you! This phone is really well-built, and a bear to disassemble. This guide had exactly what I needed to see.
Roy Thomasson - Contestar
this was a rockin' guide!!! looked everywhere and here it is, and yes a bear but a cool one!
apriltanner1975 - Contestar
Thank You! Hope this new battery works better than the old one!
autococker13 - Contestar
Yeah it's kind of helpful.
Sebastian ballensky - Contestar
where will i get the battery for the my own phone now
Timothy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 8,412
