Saltar al contenido principal
Moto Z Speaker Replacement
Qué necesitas
  1. Moto Z Speaker Replacement, Display Assembly: paso 1, imagen 1 de 1
    • Heat an iOpener and apply it to the left edge of the phone for at least 90 seconds.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
    • As you're waiting for the adhesive to soften, move on and read the following step to get an idea of where to pry.
  2. Moto Z Speaker Replacement: paso 2, imagen 1 de 2 Moto Z Speaker Replacement: paso 2, imagen 2 de 2
    • In the following steps you will be cutting through the adhesive around the edge of the display assembly.
    • To avoid damage, do not cut in the following areas:
    • The OLED panel
    • The home button
    • The flash unit
  3. Moto Z Speaker Replacement: paso 3, imagen 1 de 3 Moto Z Speaker Replacement: paso 3, imagen 2 de 3 Moto Z Speaker Replacement: paso 3, imagen 3 de 3
    • Apply a suction cup as close to the heated edge as possible.
    • Lift on the suction cup and insert the tip of an opening pick into the gap.
    • Do not insert the pick more than 1/16" (1.5 mm). Over-inserting the pick may damage the OLED panel.
  4. Moto Z Speaker Replacement: paso 4, imagen 1 de 3 Moto Z Speaker Replacement: paso 4, imagen 2 de 3 Moto Z Speaker Replacement: paso 4, imagen 3 de 3
    • Carefully slide the tip of the opening pick down and up the side of the phone, making sure not to cut deeper than 1/16" (1.5 mm).
    • As you run the pick along the side, you will feel the tip of the pick press against the edge of the OLED panel. That is as far as the pick should go without damaging the panel.
    • Once you have separated the adhesive, leave an opening pick in the side to keep the adhesive from resealing.
  5. Moto Z Speaker Replacement: paso 5, imagen 1 de 1
    • Repeat the heating, lifting, and cutting steps for the remaining long edge of the phone.
  6. Moto Z Speaker Replacement: paso 6, imagen 1 de 1
  7. Moto Z Speaker Replacement: paso 7, imagen 1 de 2 Moto Z Speaker Replacement: paso 7, imagen 2 de 2
    • Insert an opening pick into the flash side corner of the phone and carefully slice around the flash unit.
    • Do not insert the pick more than 1/16" (1.5 mm) into the edge.
    • Once you are done cutting, leave the pick in the corner to prevent the adhesive from resealing.
  8. Moto Z Speaker Replacement: paso 8, imagen 1 de 3 Moto Z Speaker Replacement: paso 8, imagen 2 de 3 Moto Z Speaker Replacement: paso 8, imagen 3 de 3
    • Insert an opening pick into the remaining top corner of the phone.
    • Carefully slice through the adhesive across the top of the phone.
    • Do not insert the pick beyond 1/2" (12.5 mm).
  9. Moto Z Speaker Replacement: paso 9, imagen 1 de 1
    • Apply a heated iOpener to the bottom edge of the phone for at least 90 seconds.
  10. Moto Z Speaker Replacement: paso 10, imagen 1 de 3 Moto Z Speaker Replacement: paso 10, imagen 2 de 3 Moto Z Speaker Replacement: paso 10, imagen 3 de 3
    • Insert an opening pick into a bottom corner and slice towards the home button, stopping before you reach it.
    • Once you're done with the corner, leave a pick in place to prevent the adhesive from sealing.
    • Repeat the process for the other bottom corner.
  11. Moto Z Speaker Replacement: paso 11, imagen 1 de 2 Moto Z Speaker Replacement: paso 11, imagen 2 de 2
    • Carefully twist the first opening pick slightly to help release the edge adhesive.
    • Repeat the same process for each remaining pick, moving them as necessary and twisting slightly to release the adhesive.
  12. Moto Z Speaker Replacement: paso 12, imagen 1 de 3 Moto Z Speaker Replacement: paso 12, imagen 2 de 3 Moto Z Speaker Replacement: paso 12, imagen 3 de 3
    • Lift the earpiece end of the display up to provide access to the display cables.
    • Do not open the display beyond 90 degrees, and always support the display panel.
  13. Moto Z Speaker Replacement: paso 13, imagen 1 de 3 Moto Z Speaker Replacement: paso 13, imagen 2 de 3 Moto Z Speaker Replacement: paso 13, imagen 3 de 3
    • Use the point of a spudger to pry the display cable shield up.
    • Remove the display cable shield.
  14. Moto Z Speaker Replacement: paso 14, imagen 1 de 2 Moto Z Speaker Replacement: paso 14, imagen 2 de 2
    • Use the point of the spudger to lift and disconnect the display cable connector from its socket.
  15. Moto Z Speaker Replacement: paso 15, imagen 1 de 2 Moto Z Speaker Replacement: paso 15, imagen 2 de 2
    • Remove the display assembly.
    • Compare your new replacement part to the original part. You may need to transfer remaining components (such as the flash lens) or remove adhesive backings from the new part before installing.
    • Before you reinstall the display assembly, thoroughly remove any remaining adhesive and glass from the frame.
    • After removing all traces of glue and glass from the frame, clean the adhesion areas with 90% (or higher) isopropyl alcohol and a lint-free cloth or coffee filter.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • Use the Motorola Moto Z display adhesive to reseal your phone. Follow this guide for instructions on how to apply adhesive to the replacement screen.
  16. Moto Z Speaker Replacement, Speaker: paso 16, imagen 1 de 1
  17. Moto Z Speaker Replacement: paso 17, imagen 1 de 2 Moto Z Speaker Replacement: paso 17, imagen 2 de 2
    • Lift up and remove the speaker with the spudger.
    • It's best to use the blue iFixit opening tool to pry off the speaker. Metal tools can be dangerous.
Conclusión
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Check out our Motorola Moto Z Answers community for troubleshooting help.
2 personas más completaron esta guía.
Miriam Lam
Miembro Desde 01/24/18
1,188 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S2-G2, Livingston Winter 2018 Miembro de Cal Poly, Team S2-G2, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G2
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 2,375
