Saltar al contenido principal
Mityvac MV8000 O-ring Replacement
Qué necesitas
  1. Mityvac MV8000 O-ring Replacement, O-ring Seals: paso 1, imagen 1 de 1
    • Remove the silver cotter pin that holds the gauge to the body of the pump.
    • With the cotter pin removed, simply pull the gauge straight up and away from the body; it does NOT screw in but instead is a friction fit. The cotter pin is what prevents it from coming out. Be sure not to lose the small wave washer between the gauge and the body.
  2. Mityvac MV8000 O-ring Replacement: paso 2, imagen 1 de 1
    • With the gauge removed from the body you can now carefully use a flat blade screw driver, or a small hook, to remove the black o-ring from the brass stem on the gauge.
    • Match the size of this o-ring with one from your kit. Likely, the new o-ring will have a slightly thicker "section" or thickness but should have the same inner diameter. In this application the best choice was a 2mm section, 4.4mm inner diamater o-ring.
    • Rub a small amount of synthetic, preferably silicone based grease on the o-ring.
    • Set aside the gauge until reassembly.
  3. Mityvac MV8000 O-ring Replacement: paso 3, imagen 1 de 1
    • Remove the two screws on the front of the pump body. A #0 screw driver works well. The front cover of the pump can then be gently pulled forward away from the pump body.
  4. Mityvac MV8000 O-ring Replacement: paso 4, imagen 1 de 1
    • With the front cover removed you can pull off the o-ring with your screw driver and find an appropriate replacement in your kit.
    • Grease the o-ring with synthetic grease and set aside for re-assembly.
  5. Mityvac MV8000 O-ring Replacement: paso 5, imagen 1 de 1
    • At this point, with the front cover removed, the final component is the rear portion of the pump. This contains the pump piston, which is round and visible on the opposite side of the handle.
    • Remove the two #0 screws holding the rear cover on over the back of the pump; it's between the rear of the pump and the handle.
    • Use your fore-finger to push in on the piston; the spring inside is fairly strong, get a helpful second set of hands if necessary.
    • The piston must be pushed far enough back to expose the shaft past the handle. Once the shaft is fully exposed, the retaining pin will slip out (not pictured). The pin goes in to the whole pictured.
    • With the shaft retaining pin removed, the piston will now push out of the rear body of the pump due to the spring tension.
  6. Mityvac MV8000 O-ring Replacement: paso 6, imagen 1 de 2 Mityvac MV8000 O-ring Replacement: paso 6, imagen 2 de 2
    • Once the piston is protruding from the body, you are ready to replace this final o-ring. You can choose to leave the piston in the body, or remove it, the shaft, and the spring. The choice is yours.
    • Pictured here is the pump completely disassembled, with the piston removed, for reference.
    • Remove the o-ring on the piston like you did the others. Find a suitable replacement.
    • Lubricate both the o-ring and the inside of the piston cylinder with a light coating of synthetic grease.
  7. Mityvac MV8000 O-ring Replacement: paso 7, imagen 1 de 1
    • For reference, you can see a comparison here. The original MityVac o-ring is on top, the new o-ring is below. The new o-ring is slightly thicker and, as long as it fits in the body of the pump without binding, it should provide a better and longer lasting seal.
Conclusión
Reassembly of the device is the opposite of dis-assembly.
Una persona más ha completado esta guía.
Nicolas Siemsen
Miembro Desde 12/06/13
39,100 Reputación
79 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
321 Miembros
1,466 Guías creadas
Un comentario
Great article. Here are some O Rings that I found I could use for this repair:
A.) The small one used at the base of the vacuum gauge: 3/16” x 5/16” x 1/16” (No.: #008)
B.) The O ring around the front cap: 3/4” x 1” x 1/8” ( No.: #210 )
C.) The O ring around the piston: Not able to find a replacement. Possibly a #211 or a #313 or 3x19 metric?
Name Not Available - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 43
Todo El Tiempo: 9,963
