Saltar al contenido principal
Inglés
Español
Paso 2
With the gauge removed from the body you can now carefully use a flat blade screw driver, or a small hook, to remove the black o-ring from the brass stem on the gauge.
  • With the gauge removed from the body you can now carefully use a flat blade screw driver, or a small hook, to remove the black o-ring from the brass stem on the gauge.
  • Match the size of this o-ring with one from your kit. Likely, the new o-ring will have a slightly thicker "section" or thickness but should have the same inner diameter. In this application the best choice was a 2mm section, 4.4mm inner diamater o-ring.
  • Rub a small amount of synthetic, preferably silicone based grease on the o-ring.
  • Set aside the gauge until reassembly.
Insertar traducción aquí
