Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Mitsubishi Diamondpoint NXM76LCD Speaker Replacement
Qué necesitas
  1. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: paso 1, imagen 1 de 3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: paso 1, imagen 2 de 3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: paso 1, imagen 3 de 3
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the 5 screws: paso 2, imagen 1 de 1
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: paso 3, imagen 1 de 3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: paso 3, imagen 2 de 3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: paso 3, imagen 3 de 3
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the four screws: paso 4, imagen 1 de 2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the four screws: paso 4, imagen 2 de 2
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: paso 5, imagen 1 de 2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: paso 5, imagen 2 de 2
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the front board: paso 6, imagen 1 de 2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the front board: paso 6, imagen 2 de 2
    • Remove the three Phillips #2 screws.
    • Remove the two data/power cables.
    • Remove the two speaker cables.
  7. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: paso 7, imagen 1 de 2 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: paso 7, imagen 2 de 2
    • Remove the Phillips #2 screws from the speaker(s).
  8. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: paso 8, imagen 1 de 3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: paso 8, imagen 2 de 3 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: paso 8, imagen 3 de 3
    • Pull the speaker off the slots.
Conclusión
Una persona más ha completado esta guía.
Padraic Hoselton
Miembro Desde 08/22/17
4,369 Reputación
12 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 29
Ultimos 30 días: 92
Todo El Tiempo: 412
