Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Mitsubishi Diamondpoint NXM76LCD Display Replacement
Qué necesitas
  1. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: paso 1, imagen 1 de 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: paso 1, imagen 2 de 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Removing the stand.: paso 1, imagen 3 de 3
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: paso 2, imagen 1 de 1
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: paso 3, imagen 1 de 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: paso 3, imagen 2 de 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the back panel: paso 3, imagen 3 de 3
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: paso 4, imagen 1 de 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: paso 4, imagen 2 de 2
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: paso 5, imagen 1 de 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the 5 screws: paso 5, imagen 2 de 2
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the front panel: paso 6, imagen 1 de 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the front panel: paso 6, imagen 2 de 2
    • Remove the three Phillips #2 screws.
    • Remove the two data/power cables.
    • Remove the two speaker cables.
  7. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: paso 7, imagen 1 de 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: paso 7, imagen 2 de 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display cable: paso 7, imagen 3 de 3
    • Pull the two tabs.
    • Pull the connector off.
  8. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the power switch: paso 8, imagen 1 de 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the power switch: paso 8, imagen 2 de 2
    • Remove the switch cable off.
    • Remove the two Phillips #2 screws.
  9. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display power: paso 9, imagen 1 de 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the display power: paso 9, imagen 2 de 2
    • Remove the four display power cables.
    • These cables are interchangeable.
  10. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: paso 10, imagen 1 de 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: paso 10, imagen 2 de 3 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Lift the display out: paso 10, imagen 3 de 3
    • Lift the display out.
  11. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: paso 11, imagen 1 de 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement, Remove the four screws: paso 11, imagen 2 de 2
    • Remove the four Phillips #2 screws.
    • These screws release the display from its enclosure. Hold the screen when removing these screws.
  12. Mitsubishi Diamondpoint NXM76LCD  Display  Replacement: paso 12, imagen 1 de 2 Mitsubishi Diamondpoint NXM76LCD  Display  Replacement: paso 12, imagen 2 de 2
    • Remember to plug in all the cables on the display.
Conclusión
2 personas más completaron esta guía.
Padraic Hoselton
Miembro Desde 08/22/17
4,369 Reputación
12 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 405
