Introducción
This guide takes a deep dive into dissassembling and replacing the battery of the Microsoft Surface Book Keyboard.
Qué necesitas
Herramienta utilizada en este paso:Jimmy$7.95
You should use an iFixit jimmy tool, a set of screwdrivers conaining a Torx T4, and a phillips bit, and an iOpener. You can be risky like me and use a hair dryer and a scraper! The T4 is necessary though
Heat up the area until unpleasant to touch using a heat gun or hair dryer.
This should be around 130 degrees Fahrenheit.
Insert jimmy.
Tilt the jimmy flat.
Give a pick a little room to insert.
pull out the jimmy.
Insert into a different location on the device
Grab a nonmetal bucket, and fill it with sand. (1/2 gallon should do it)
This is in case the batteries get punctured or catch fire when being removed.
See here: iFixit Battery Safety
Gently, take your opening picks, and VERY, VERY gently, scrape the adhesive out from under the battery.
Put the batteries in the bucket and take them to a nearby battery recycling facility. battery recycling facility list
Unpackage your new, beautiful, fantastic Surface Book Keyboard battery.
Take that battery, and take some of that adhesive, stick it to the back of the battery.
Put it on the backplate.
Plug in the connector that was keeping you from being able to pull the backplate off.
Take your adhesive, line the edges with the adhesive and put the backplate back on
Congratulations! You did it!
TYSM for reading this guide!
4 personas más completaron esta guía.
1Guía Comentario
Which adhesives should I purchase for this replacement?
