Saltar al contenido principal
Microsoft Surface Book 2 15" Rear Camera Replacement
Qué necesitas
  1. Microsoft Surface Book 2 15" Rear Camera Replacement, Motherboard: paso 1, imagen 1 de 1
    • Open the laptop, then orient it so the touchpad is on your left.
    • Starting at the hinge, count six holes up on the tablet portion of the laptop.
  2. Microsoft Surface Book 2 15" Rear Camera Replacement: paso 2, imagen 1 de 2 Microsoft Surface Book 2 15" Rear Camera Replacement: paso 2, imagen 2 de 2
    • Take a paper clip and unfold it.
    • Place the paperclip in the sixth hole and push until you hear a click.
    • Once you hear the click, lift up on the right side of the tablet from the base until it separates.
    • After the right side has been detached, lift up the left side as well.
  3. Microsoft Surface Book 2 15" Rear Camera Replacement: paso 3, imagen 1 de 1
    • Place the tablet on a flat surface.
    • Using a heat gun or iOpener, heat up the edges of the screen to soften up the adhesive.
  4. Microsoft Surface Book 2 15" Rear Camera Replacement: paso 4, imagen 1 de 1
    • Using a plastic pick, slice underneath the edge of the screen.
    • Use a suction cup to carefully lift the screen and create separation between the screen and frame.
    • Take care not to insert the tool too far to avoid cutting the ribbon cables.
    • Slowly make your way around the screen, and carefully cut the adhesive that secures the screen to the frame.
    • Don't use a metal tool, that could damage the screen or internal parts.
  5. Microsoft Surface Book 2 15" Rear Camera Replacement: paso 5, imagen 1 de 2 Microsoft Surface Book 2 15" Rear Camera Replacement: paso 5, imagen 2 de 2
    • Lift up the screen.
    • Detach the ribbon cables connecting the underside of the screen to the motherboard.
  6. Microsoft Surface Book 2 15" Rear Camera Replacement: paso 6, imagen 1 de 2 Microsoft Surface Book 2 15" Rear Camera Replacement: paso 6, imagen 2 de 2
    • Use a T3 Torx screwdriver to remove eleven 4 mm screws from the motherboard.
    • Use a T3 Torx screwdriver to remove the ten 2.5 mm screws from the top bar.
  7. Microsoft Surface Book 2 15" Rear Camera Replacement: paso 7, imagen 1 de 1
    • Once the screws are removed from the top bar, gently lift up and remove it.
    • Be careful not to damage any ribbon cables or wires.
    • Gently lift up on the motherboard to remove it.
  8. Microsoft Surface Book 2 15" Rear Camera Replacement, Front Camera: paso 8, imagen 1 de 1
    • After lifting the motherboard, locate the two cameras near the center of the motherboard.
    • Unplug front camera (right side) from the motherboard (lift carefully).
  9. Microsoft Surface Book 2 15" Rear Camera Replacement, Rear Camera: paso 9, imagen 1 de 1
    • In the top left-hand corner of the tablet is where the camera sits.
    • Unscrew the T3 torx screw.
  10. Microsoft Surface Book 2 15" Rear Camera Replacement: paso 10, imagen 1 de 1
    • Unplug the camera from the connector and remove.
Conclusión
Una persona más ha completado esta guía.
Colton Almeida
Miembro Desde 03/13/23
172 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 17
Todo El Tiempo: 138
