Introducción
How to replace the valve plate in a Mi-T-M Air Compressor AM1-PH65-08HD 2012.
Qué necesitas
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Pull the ring on the safety relief valve away from the compressor tank to drain the air from the compressor.
Use a 7/8 inch wrench to loosen the nut securing the pump discharge line to the elbow on the cylinder head.
Use a 10 mm socket to remove the bolt securing the belt guard.
Tilt the belt guard away from the device and lift it out to remove it.
Use a 7/16 inch socket to remove the nuts and accompanying bolts securing the belt guard bracket to the rear belt guard.
Use a 1/2 inch socket to remove the four remaining bolts securing the cylinder head:
Two 2 1/8 inch-long bolts
Two 2 1/2 inch-long bolts
Push up on one of the valve plate tabs to break the seal between the valve plate and the gasket.
Remove the valve plate.
Una persona más ha completado esta guía.
