Introducción
Use this guide to remove or replace the adjustable regulator on a Mi-T-M Air Compressor AM1-PH65-08HD 2012.
Qué necesitas
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Pull the ring on the safety relief valve away from the compressor tank to drain the air from the compressor.
Use a 7/16 inch wrench to loosen the nut securing the pressure gauge to the regulator housing.
Fit an adjustable wrench to the black metal square on the hose side of the regulator.
Use a 3/4 inch wrench to hold the nipple in place.
Use a 1/2 inch socket and wrench to remove the two bolts and accompanying nuts securing the regulator mounting bracket to the frame.
Lift the regulator off of the mounting bracket.
Use your fingers to unscrew and remove the mounting bracket from the regulator.
Unscrew the adjustable regulator from the hose barb.
Remove the regulator.
Use a 3/16 inch hex key to remove the plug from the regulator.
Only the regulator remains.
